![]() Enthusiast ![]() ![]() ![]() Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) ![]() |
I had too much pressure on my crank case. would an oil resivoir help any?
-------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
what weight oil are you using ?
the lower the weight/viscosity the lower the pressure. 5w-30 is the best way to go. what is your pressure ? -------------------- |
I wouldnt use that thin of an oil on a 100,000+ engine.
i'm using 10w30 and all my seals are broken on the case, i dont know what pressure. It was with a turbo.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
what psi were you boost on what size of turbo?
-------------------- yea your 3sgte is cool but ill stick to my 7agte
7psi and t-26 i think
use an oil pressure regulator....you don't wanna see more then 55psi at the turbo
any info on it? any suggestions on which to buy, where it goes, who has one?
www.atpturbo.com has some in-line restrictors for the turbos, i dont know about the sizes and stuff for you guys tho.
ill check into it abit more at some point today and get back. ![]() going off dustins(bat) pressure, i would think that you prolly would need some kind of restrictor in there. ::Edit:: somthing like this : oil restrictor ![]() This post has been edited by presure2: Aug 27, 2005 - 10:35 AM -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: February 24th, 2025 - 6:26 PM |
