nitrious install |
nitrious install |
Aug 24, 2005 - 9:39 PM |
Enthusiast Joined Aug 6, '05 From plattsburgh NY (way upstate) Currently Offline Reputation: 0 (0%) |
just did a zex kit install having a fiew problems the wire from the TPS sensor the highest voltage i get from it at wot is 3.9 volts so it wont so it wont break the boundry to turn on the nitrious. also just to make sure i hooked up the vacuume lines up right one goes to the intake mani and the other to the fuel pressure regulator which is on the pass side of the engine down low almost underneath the intake manifold.
Lo-Fi Version | Time is now: November 26th, 2024 - 4:54 PM |
