> turbo
post May 1, 2003 - 7:53 AM
Celica2085TA
Joined Sep 18, '02
From Masachusettes
someone should post a how-to artical on instaling a turbo and were they got the parts from and how much labor and cost is. just an idea
post May 1, 2003 - 8:21 AM
macavely
Joined Nov 4, '02
yea i agree
post May 1, 2003 - 9:29 AM
Charlie97L
From North Bethesda, MD
here's the minimum list:
turbo
manifold
oil lines
bigger injectors
FMU or AFC
fuel pump
blow off valve
IC (optional: needed for more than 5 psi)
piping
custom downpipe
intake filter
turbo flange
a/f gauge (not needed if you got an AFC)
boost gauge
egt gauge
gauge pod
check valve
optional:
external wastegate
boost controller
turbo timer
more gauges
ignition timing controller
any other goodies you want
you'll also need stuff like oil, gaskets or gasket maker, hoses, etc. i spent about 3500 so far, i definitely went the most $$ route you could go, i bought everything new, and added a lot of optional stuff.
prices depend on what you get, labor depends on where you go. if you have any questions about the install, post em. you really should read up and do some research yourself. turboing is tricky, and it's better if you understand exactly what's going on with your car. i've spent close to 3500 on my 7afte, but you can get it done probably for 2000 if you buy used stuff and really shop.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post May 1, 2003 - 9:48 AM
this is why i changed the entire engine - its cheaper and will last longer.
post May 1, 2003 - 11:43 AM
Celica2085TA
Joined Sep 18, '02
From Masachusettes
thanks
post May 1, 2003 - 12:03 PM
zigy
Joined Nov 6, '02
From Chicago, IL
yea but if I put turbo on my beefy "Automatic"....hehee.... one word!!!!!
SLEEPER
(i wanna see 7afe get into 13s though)
post May 2, 2003 - 1:33 AM
Charlie97L
QUOTE (zigy @ May 1, 2003 - 9:17 AM)
SLEEPER
ha, good luck with that.
1994 Lexus ES300
1989 Supra Turbo
post May 2, 2003 - 2:08 AM
Guest_Matthew_*
SLEEPER
well just having a 6th gen celica with a 3s-gte is a sleeper in itself.. i mean taking a 2400 135 hp car to a 2600 200-255hp car. thats quite a difference...
the reason i made the weight go up is because the 5s-fe is aluminum and the 3s-gte is cast iron. and it weighs more.
post May 2, 2003 - 8:49 AM
zigy
Joined Nov 6, '02
From Chicago, IL
...la...la...la...
well, I have seen Corollas equiped with 7AFE get into 13s
(the only problem - they they were "not Auto")
but it's always possible to beef up auto trans
(**** my handles 14.7 QM)
post May 2, 2003 - 11:56 AM
Rivo
Joined Apr 28, '03
Race Prepped 3sge will kick some serious ass, gee...someone should do that... rolleyes.gif biggrin.gif
post May 3, 2003 - 11:25 AM
HyperDeathKill
Joined Apr 20, '03
From Chicago
QUOTE (zigy @ May 2, 2003 - 6:03 AM)
How do you do that Ziggy?
post May 3, 2003 - 3:23 PM
zigy
Joined Nov 6, '02
From Chicago, IL
QUOTE (HyperDeathKill @ May 3, 2003 - 8:39 AM)
custom bro, custom......
I see that you live in Chicago... If you need any hookups let me know....
Lo-Fi Version Time is now: November 24th, 2024 - 9:57 AM
