I Don't get it anymore?, Engine seems to work somewhat now..... |
Aug 26, 2005 - 12:19 AM |
Ok, so back to my 4age ST. I fried the ECU a while back and the car had terrible F/A mixture. Today, I got a new Distrubtor cap and installed it in the engine along with the rotor. The old one had a crack on it where the spark wire went to CYL 2 or 3 not sure anymore.
Anways So I hook up the Fried ECU to test the new cap and rotor and WHAM! The engine starts working ok again with good A/F Mix ( 8% rich). WTF is with this? The engine seems to work when it wants too and doesn't when it doesn't feel like it. I wonder if my engine is cursed? (Like some Japanses guy died drifting in it) Oh Yeah, FYI an engine will not start if the ECU was just plugged in and hasn't recevied the chance to 'boot up'. (I feel like an idiot) |
Aug 27, 2005 - 12:36 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Probably the ECU reset itself, and also the crack in the distributor might have had something to do with it.
As in the 2 cylinders could have not been getting strong enough spark to burn the fuel causing it to run rich. This post has been edited by Rjb23: Aug 27, 2005 - 12:38 PM |
Aug 27, 2005 - 2:32 PM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
what are u measureing you A/F with to make these claims?
any problems in your ignition system will cause the car not to run or if it could run, it will run like ****. |
Lo-Fi Version | Time is now: November 30th, 2024 - 11:02 AM |
