Oil Drain Valve |
Oil Drain Valve |
Aug 28, 2005 - 1:25 PM |
Enthusiast Joined Aug 13, '03 From Greencastle, PA Currently Offline Reputation: 0 (0%) |
Does anyone have one of these?
Oil Drain Valve I was thinking about getting one for my Xterra and wondered if any of you guys have tried it. Thanks. |
Aug 29, 2005 - 3:40 PM |
bump.
Aug 30, 2005 - 1:01 AM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
if you're too lazy to undo one bolt to drain your oil then you have problems I guess. I can see that valve being a problem if you drive in offroad conditions where something may catch on the undercarriage and open that valve up (that would end up being my luck at least).
I figure just stick with the whole bolt thing. Unless you have a stupid Sunfire like my fiance does, I almost pulled the car off the jack and on top of me trying to torque the bolt off of the oil pan it was on so tight -------------------- 1999 Celica GT
Aug 30, 2005 - 6:37 AM |
I'm kind of thinking the same way, I think its a good idea, just not sure if its practical. I also wondered about the ground clearance, but apparently no one has any prior knowledge of it.
Lo-Fi Version | Time is now: January 10th, 2025 - 2:00 PM |
