> took back seats out, need more room
post Aug 29, 2005 - 10:02 PM
FSX_Celica94GT
Joined Nov 26, '03
From Texas
so i took my back seats out over the weekend cuz i need more room to put stuff since i have a giant sub box in the back of my car. I need more room for my back pack and computer when i go to lan parties (noone ever sits back there anyways), but my question is, since theres absolutely no carpet underneath the seats and theres 2 dips in the back where the seats were, i was wondering what would be the best option to fill this in with? i was thinkin about gettin some carpet and just putting it back there, but then i decided i was gonna move my subs up so i can have an easier time getting my backpack out. Maybe a thick board cut to fit the back would be best? what do yall think?
post Aug 29, 2005 - 10:26 PM
Chanh55
Joined Jun 29, '03
I took my back seats out as well and have the same problem. For a clean look, I was thinking about cutting plywood, line it with carpet and fit it in. Option 2 is get a roll cage made, how sweet would that be...
post Aug 30, 2005 - 1:33 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
QUOTE(Chanh55 @ Aug 29, 2005 - 10:26 PM)
[right][snapback]329289[/snapback][/right]
sweet but how does that cover your backseat gap? still got bare sheet metal and wire loom showing
post Aug 30, 2005 - 8:21 AM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
I had mine out for months it was ugly but they had no purpose and just had to put them back because they took up too much space outside the car. Only thing I noticed is that there are X number of wires for the fuel pump and thats the only bare wires/looming out that I had.
I plan on using each dip as a place to mount each amp and having my car recarpeted to make one giant peice that flows from front to back, then gettin my 3 rear panels redone in CF and remolding some of it to make it look like the back seats never exsisited.
DTE
I am a thief.
do not buy anything from me.
post Aug 30, 2005 - 9:07 AM
celicaST
Joined Jun 23, '05
QUOTE(Chanh55 @ Aug 29, 2005 - 9:26 PM)
measuring and building a plywood box to cover the dips would be your best option. as a temporary solution, the carpet from your trunk covers the seats very well if you put it in backwards.
post Sep 9, 2005 - 6:23 PM
gamesteristj
Joined Feb 18, '04
From Spokane Washington
In the same boat as you. No one ever sits back there and I wanna better way of showing off my stuff later.....thinking an acrylic box that will enclose everything. Thinking hard
post Sep 14, 2005 - 8:13 AM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i took my seats out as well, just to save weight. i think it took out like 30-40 lbs including the seat belts, seatbelt mech. and interior panels in the back
post Sep 15, 2005 - 11:01 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
what about that foam stuff that you can spray to seal cracks or the foam you spray inside of walls? it hardens and you can fill it up with lightweight firm foam. maybe home depot.
-Red
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Sep 17, 2005 - 1:54 AM
you can use foam but 2 things with that....
#1) it has to be removeable
#2) it can't interfer with the fuel pump
post Sep 17, 2005 - 6:31 AM
popstar
Joined Nov 24, '04
From Moscow, russia
ok !
first line the seat dips with cling film or a sheet of polythin, then fill the dips with expanding foam and cover with thick card. you now have a removeable pack for you seat well smile.gif
then cut some ply wood (MDF would be better) and cover in carpet to fit the space which should also now be level with your trunk,,,,,
good sound insulation for the music and good load space .....
Life is for living, and you don't get a second chance
Take care now !!
Lo-Fi Version Time is now: February 25th, 2025 - 12:09 AM
