Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
So before I get started let me update yall on what is going on with my celica.
-It was a 94' ST Coupe, auto -2nd gen 3sgte swap -GT Tranny 5spd, hybrid clutch (CF & Exedy) -CT26 stock turbo, stock IC, Apexi turbo timer, Boost & A/F Gauges I bought the car as you see it, with the 3s sitting just as it is. The previous owner had no idea what was going on therefor I have had to redo alot of what was done so it has taken much longer to complete due to parts hunting and redoing motor mounts. ![]() Here is a test painting of my manifold and turbo to see how the color looked, the rust still needs to be sanded off before final painting. any comments on the color tho? (and yes im using high temp paint) ![]() Here is the 5s tranny and what I thought to be a CF dual friction clutch... that I bought from eazy2001x as of right now im still awaiting axles and shift linkage. but the clutch is CF with a little exedy in its blood, the inner plate has exedy on the center where the tension springs are and on the other side it shows CF-DF pads and label... anyone have ideas? if u want pics of the clutch itself I can post those. ![]() Here is my interior awaiting shifter, clutch pedals, gauge pod for boost & a/f, and the 3s wire harness so I can reinstall the ECU. not much to say about this pic, I still have alot of work for this car. ![]() And for the last pic.. The engine bay, now no comments on how bad it looks or what looks wrong because I'm waiting for my engine stand to get freed up so I can get to maintenance work on the engine and cleaning everything up in the engine bay. Ill keep you all posted as parts arrive and the motor comes out. -Derek This post has been edited by celicast3sgte: Dec 19, 2005 - 3:02 PM -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
Sweeet. Keep us updated.
OK so heres my list of parts i still need! if anyone has the parts please PM me!
-7A-FE to 3S-GTE harness with MAF -Clutch pedal assembly with smaller brake pedal -Pillar 2 gauge pod -Apexi turbo timer harness for ST -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
there is no turbo timer harness...u have to use a universal one.
2 pillar gauge pod-lotek or your local parts shop 7afe-3sgte wiring harness. you have one in your car and hopefully you were smart and bought a clip......take both harnesses out send to DG and fork over 500$ |
QUOTE(playr158 @ Aug 30, 2005 - 3:35 PM) there is no turbo timer harness...u have to use a universal one. 2 pillar gauge pod-lotek or your local parts shop 7afe-3sgte wiring harness. you have one in your car and hopefully you were smart and bought a clip......take both harnesses out send to DG and fork over 500$ [right][snapback]329490[/snapback][/right] lotek doesnt make a 2 gauge pod for the 94-99 theyre 3 pod, and read the top of my post more cause I bought the car like this i didnt start the swap there for a clip was not available... I wish it was tho ![]() -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
me and u gotta talk man....
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) ![]() |
i may have clutch pedal assembly...should know by Sunday
QUOTE(easternpiro1 @ Aug 31, 2005 - 9:44 AM) me and u gotta talk man.... [right][snapback]329752[/snapback][/right] aright PM me then. QUOTE(Consynx @ Aug 31, 2005 - 10:12 AM) i may have clutch pedal assembly...should know by Sunday [right][snapback]329762[/snapback][/right] sweet, send me a PM when u know, im also going to a junkyard (nix99) they have a GT there im gonna see what they want for the whole car or just the pedals but im sure itll be more from them.. anyways let me know! -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
QUOTE(celicast3sgte @ Aug 31, 2005 - 11:54 PM) QUOTE(easternpiro1 @ Aug 31, 2005 - 9:44 AM) me and u gotta talk man.... [right][snapback]329752[/snapback][/right] aright PM me then. QUOTE(Consynx @ Aug 31, 2005 - 10:12 AM) i may have clutch pedal assembly...should know by Sunday [right][snapback]329762[/snapback][/right] sweet, send me a PM when u know, im also going to a junkyard (nix99) they have a GT there im gonna see what they want for the whole car or just the pedals but im sure itll be more from them.. anyways let me know! [right][snapback]330036[/snapback][/right] Do a rear brake conversion if you can!! You can get cheap pillars on ebay! |
do you even have the wiring harness for the 3sgte?
if you do then take it off..... take out the 7afe one from your car and send it out.....doesn' matter clip or not really... |
its a cut 3s harness and i dont know if connectors are missing... i would like to find someone with a pre fab. harness so i can just plug and play! ill trade my stock 7a and cut 3s harness to anyone if they want to then make another harness and sell it?
ANOTHER UPDATE: I got clutch & brake pedals!! i went to a local junk yard on HW99 and picked em up at 8 this moring! ill have pics later tonight when i start to install them. I also got the shifter so that means my interior gets to go backtogether!! ![]() -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Parts Needed:
-7A-FE to 3S-GTE OBD1 harness with MAF -2 Gauge Pillar Pod Parts For Sale: -7A-FE ECU 94' OBD1 $50 obo -ST185 Alltrac transmission w/ transfer case & Shifter + Cables $100 obo -3S-GTE Flywheel & Clutch combo $100 obo This post has been edited by celicast3sgte: Sep 4, 2005 - 2:07 AM -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) ![]() |
Why are you selling your 3s flywheel and clutch?
selling the clutch because it didnt fit the GT tranny im running and i got aftermarket anyways, the flywheel because i have 2 now, so if your interested i can get pics and we can talk about a price. my cell # is 425-308-7627
Nah I have one too, just was wondering why because you need one for the swap.
QUOTE(Rjb23 @ Sep 4, 2005 - 9:51 AM) Nah I have one too, just was wondering why because you need one for the swap. [right][snapback]330998[/snapback][/right] oh ok well anyone that needs one i think it needs to be resurfaced but im basically giving it away! anyone thats interested let me know. Now for the fun part... ![]() overall progress of the car, all i am waiting for is my engine stand so i can take the motor out and do maintainance then i can reassemble it with the new transmission. (alltrac trans is pictured) ![]() its now officially a manual! i just installed the other brake pedal and all the clutch hardware as well as the shifter. im getting very anxious for the car to be completed. thats all for now ill keep updating as i get things completed. -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
Nice project you got there. Keep it up, the end result is priceless.
DEF -------------------- ![]() I will return one day. |
QUOTE(soulshadow @ Sep 1, 2005 - 10:58 AM) QUOTE(celicast3sgte @ Aug 31, 2005 - 11:54 PM) QUOTE(easternpiro1 @ Aug 31, 2005 - 9:44 AM) me and u gotta talk man.... [right][snapback]329752[/snapback][/right] aright PM me then. QUOTE(Consynx @ Aug 31, 2005 - 10:12 AM) i may have clutch pedal assembly...should know by Sunday [right][snapback]329762[/snapback][/right] sweet, send me a PM when u know, im also going to a junkyard (nix99) they have a GT there im gonna see what they want for the whole car or just the pedals but im sure itll be more from them.. anyways let me know! [right][snapback]330036[/snapback][/right] Do a rear brake conversion if you can!! You can get cheap pillars on ebay! [right][snapback]330130[/snapback][/right] hey man i just realized you posted sorry didnt get back to it... yeah the gt was roasted... head on into a wall then hit in the back. it used to have JDM tails but 1 was destroyed the other had a hole dead center... as for the interior it wasnt bad but was auto so i used the ST shifter and pedals. oh and the rear conversion would be nice but it was missing the calipers which are one of the biggest pieces to the puzzle. -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
So DHL lost my passenger side axle... lame im supposed to get a call today if they found it. Hopefully they find it if not im asking for some money back.
![]() oops.. its the passenger side (longer one) that they lost. I got a call today and they asked for some details and all i had was its a long rod made out of metal with 2 rubber boots on it... lol anyone have like part #s for these? This post has been edited by celicast3sgte: Sep 9, 2005 - 1:20 AM -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
edited this post out it does not attribute to the swap
This post has been edited by celicast3sgte: Dec 19, 2005 - 3:12 PM -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:46 PM |
