> Car won't start...help please, urgent
post Aug 31, 2005 - 12:13 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
okay since this is my only mode of transportation im really in a hurry here. my car won't start....it just wont turn over...the batteries not dead...soooo...starter? spark plugs? anyone got suggestions? i dont know what to look for
- Ryan
aim: rkgreen04
post Aug 31, 2005 - 12:18 AM
first check the basics...fuses, gas, alarm starter kill switch....
post Aug 31, 2005 - 12:23 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
no alarm, gas is full. What fuses? I'm an electrical klutz.
- Ryan
aim: rkgreen04
post Aug 31, 2005 - 12:25 AM
Burt
Joined Mar 9, '04
is the engine getting fuel?
is the engine getting air?
check all hoses that see vacuum.
what kind of noise does it make?
does everything electrical work?
what recent work have you done?
check the neutral safety switch
EDIT: check ALL fuses.
This post has been edited by Burt: Aug 31, 2005 - 12:27 AM
post Aug 31, 2005 - 12:26 AM
Abraxis64
Joined Mar 4, '05
From hawaii
it won't turn over? when you turn the key, does it simply click? if yes, try to get a buddy to turn the key for you and, when s/he does, bang on the starter with like a rubber mallet and a rod or something; if it starts to turn over, then the starter is your problem. if this method does get your car to turn, you may have to adjust your crank pulley in order to get it to actually start--that was the process for my crx, anyway.
peace
post Aug 31, 2005 - 12:43 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
no it chugs but wont turn on. i dont think i have a neutral safety switch haha. Its not making any different noises.
- Ryan
aim: rkgreen04
post Aug 31, 2005 - 1:48 AM
Burt
Joined Mar 9, '04
you should have a neutral safety switch...unless you have a manual and can start your car without the clutch pressed in.
what do you mean by chugs??
do you have an Aol instant messenger name or a yahoo messenger name? I am pretty good with mechanical work so maybe I could help you if we could talk with faster responses than this board
post Aug 31, 2005 - 4:37 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Akimbo, check for spark first. If your getting spark from all 4 plugs, check that getting fuel. If no spark, you broke your timing belt. it just happened to me
post Sep 7, 2005 - 1:10 AM
exxtractor
Joined Mar 31, '03
From BC
so what was the problem? My guess was starter contacts were worn out.
post Sep 7, 2005 - 7:44 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
check the two wires you connected when swapping to manual
Burt has the idea I was thinking of, but i was guessin maybe the two wires weren't soldered? fell off and now you can't start.
post Sep 7, 2005 - 8:27 AM
Nigel
Joined Aug 21, '03
From UK Liverpool
hi this happened to mine, can u try jumping it? all my lights worked but it turned out to be the batt, so try jumping it.
post Sep 7, 2005 - 9:38 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(Consynx @ Sep 7, 2005 - 12:44 PM)
[right][snapback]331644[/snapback][/right]
If it turns over this isn't the problem. If it turns over slowly it may be that it doesn't have good contact.
post Sep 8, 2005 - 2:15 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
ignition coil btw, solved. thanks though
- Ryan
aim: rkgreen04
Lo-Fi Version Time is now: November 23rd, 2024 - 12:53 PM
