> timing belt installed woo hoo!, Not that hard.
post Aug 31, 2005 - 1:46 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Yay. my! car is running again. I installed a timing belt, water pump and a new power steering belt. The job was not that hard. I used all 3 celica manuals and picked up tips from all 3. The hardest part was trying to remove the crankshaft pulley without a crankshaft pulley holding tool. After a day of trying all kinds of different things, a friend said why dont I just use his impact wrench. It came off in seconds! The next hardest thing was, the books did not call out a bolt that was under the engine mounting bracket. Its there. removing the engine mounts was easy, and I had to jack the engine up and down to get to bolts from the bottom and the top of the car. Use a hydraulic jack. Other then that, its not hard and i consider myself more of a body man then a mechanic.
post Aug 31, 2005 - 2:53 PM
blu94gt
Joined Mar 23, '05
From Kansas City
I need to have mine done, but I think I'm going to just take it to the Toyota dealer in town, I don't really feel like bothering with it.
1999 Celica GT
post Aug 31, 2005 - 2:57 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
probably 4-500 at the dealership?
post Aug 31, 2005 - 3:04 PM
celicaboston1983
Joined Mar 20, '04
i paid 300 for mines. dont have the balls to mess with it and f#ck it up
post Aug 31, 2005 - 10:43 PM
Jaws4God
Joined Mar 27, '04
yeah i'd like to do in on my own... i have the belt already...
think you could do a how to???
post Sep 2, 2005 - 12:45 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
do you just slap the new belt on or do you have to make marks one where the old one came off and the number of grooves between the gears?
post Sep 2, 2005 - 1:41 PM
toyotatech
Joined Jun 14, '05
From colorado
QUOTE(rjbibeau @ Sep 2, 2005 - 12:45 PM)
[right][snapback]330505[/snapback][/right]
you put the engine at TDC and pull old one off and then put the new one on without moving the crank or the cam to much.
post Sep 2, 2005 - 4:59 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
thanks bro
Lo-Fi Version Time is now: November 26th, 2024 - 6:28 PM
