> is there a brake light fuse?, taillights work but doesnt get brighter
post Sep 2, 2005 - 10:01 AM
forkee
Joined Nov 13, '02
From So Cal
my brake lights dont work. the taillights turn on when its nighttime but the second lamp inside the bulbs do not activate when i step on the brake. fuses marked TAIL and ST are fine. im looking for a fuse that might go to the brake light switch.
thanks,
ray
post Sep 2, 2005 - 2:06 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Have you checked that the second filament isn't burned out? Usually the simplest explanation, unless all of them went at the same time. Occam's razor.
post Sep 2, 2005 - 3:31 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
It's labeled 15A STOP.
EDIT: Sorry. I don't know which fuse box it's in. I think it's the one under the hood though.
This post has been edited by WannabeGT4: Sep 2, 2005 - 3:37 PM
post Sep 5, 2005 - 10:14 PM
forkee
Joined Nov 13, '02
From So Cal
nope not under the hood. ur talking bout the box near the battery right? cuz theres no STOP fuse there
post Sep 6, 2005 - 10:48 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I went ahead and looked it up in the BGB. It's actually in the interior fuse box:
EDIT: Just got back from lunch. On my 94 GT it is definately in the interior fuse box just like in the picture above.
This post has been edited by WannabeGT4: Sep 6, 2005 - 12:50 PM
post Sep 6, 2005 - 7:30 PM
forkee
Joined Nov 13, '02
From So Cal
k now i feel stupid, cuz its right there...haha
k but now i have another problem
it was a blown fuse so i stuck a spare 15a in there, pressed the brake and saw the new fuse blow out too. now im out of spares, lol. any idea where it could be shorting out?? i dont have any aftermarket electrical equipment connected to my stop lights (after all, its only activated when i brake)
post Sep 6, 2005 - 8:33 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Your guess is as good as mine. If you've installed anything lately check those areas first.
post Sep 6, 2005 - 9:51 PM
take out the rear tails and check the wires (pinched or frayed). Make sure there is no water in the tail housings too. There is probably a short there. Also change the bulbs just in case.
post Jan 4, 2010 - 7:18 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
sorry to bring this from the dead, but im having trouble with my tail lights not getting brighter also.
i checked all the fuses. replaced them anyways, thinking it might of had a hair size cracked. no luck.
All my lights work. Signals front and back lights. it just doesnt get brighter when i step on the breaks... anyone know what i can look for to fix this?
i have a 96 parts car i can go to , to get what ever i need..
post Jan 4, 2010 - 7:25 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
brake switch at the pedal
Breaking Axles...
post Jan 4, 2010 - 7:35 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (pittfirefighter @ Jan 4, 2010 - 7:25 PM) *
Thank you! Imma go check now.ill be sure to take lots of pics
Lo-Fi Version Time is now: February 17th, 2025 - 6:33 AM
