7 Pages V  « < 3 4 5 6 7 >
> Its Back, in Black, and its totally badass Consex :P
post Sep 11, 2005 - 1:40 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(WannabeGT4 @ Sep 8, 2005 - 11:19 AM)
Defgeph, what is the part number for your ECU? I have what I think is a 93WRC ECU but I just wanted to double check. Thanks.
[right][snapback]332147[/snapback][/right]
ECU
Intercooler ECU
I'm happy to say I'm out of limp mode now. The car is great, I still need to get that exhaust done and hook up my boost controller.
Thanks guys
DEF
I will return one day.
post Sep 11, 2005 - 2:01 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Yup. That's what I've got. Thanks.
How'd you wire up the ECU so that you don't get that code?
This post has been edited by WannabeGT4: Sep 11, 2005 - 2:09 PM
post Sep 11, 2005 - 5:26 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
if you are looking at the ECU pins this is the plug on the right
Send WIN Pin out to ground
post Sep 11, 2005 - 6:53 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
What about INT on the 26pin.
post Sep 11, 2005 - 8:21 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I didnt touch that wire, in my harness the color is not the same as whats on that pinout.
That ECU Diagram is different from mine. That one for the CS, I have the RC.
I might mess around with it more, but for now I'm out of low boost.
And I'm loving it.
DEF
post Sep 11, 2005 - 8:29 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Sounds good. Thanks.
Yeah, WIN is actually ABS on my ECU and INT is EVP. I have no idea what they stand for though.
post Sep 11, 2005 - 8:34 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I would suggest following a ST205 pinout if you have one.
post Sep 11, 2005 - 8:40 PM
so, how much boost are u getting now?
post Sep 11, 2005 - 8:41 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
wanna do me a favor, can you post a pic of the ST205 pinouts for the plug on the left.
The colors and what they are for if you have it.
Thanks
DEF
post Sep 11, 2005 - 8:43 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(lagos @ Sep 11, 2005 - 8:40 PM)
[right][snapback]333183[/snapback][/right]
8 pounds, Its EBC time. And a less restrictive exhaust.
post Sep 11, 2005 - 8:44 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
They are similar but not exactly the same. It seems that they integrated the Intercooler ECU into the main ECU.
ST205:
This post has been edited by WannabeGT4: Sep 11, 2005 - 9:02 PM
post Sep 11, 2005 - 8:45 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(defgeph @ Sep 11, 2005 - 8:43 PM)
[right][snapback]333185[/snapback][/right]
Don't the RC ECUs have boost cut at 17 PSI? Sounds like there is plenty of room to grow once you get that MBC.
post Sep 11, 2005 - 8:52 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
This might come in handy as well:
post Sep 11, 2005 - 8:55 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(WannabeGT4 @ Sep 11, 2005 - 8:45 PM)
[right][snapback]333188[/snapback][/right]
I have a greddy profec B Spec II EBC. I think both the fuel and boost cut at 17PSI
post Sep 11, 2005 - 8:58 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I also think I need to ground one more wire, because of the IC level sensor. I still need to look into it. but I beleive the wires for it are just sitting in my harness somewhere un connected.
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(defgeph @ Sep 11, 2005 - 8:55 PM)
[right][snapback]333192[/snapback][/right]
I'm blind... LOL. just goes to show I can't multi task.
post Sep 11, 2005 - 9:00 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
lol its cool, I have the EBC. I still need to wire it up.
I might take a shot at it this week.
DEF
post Sep 11, 2005 - 10:55 PM
even tho your fuel cut is at 17psi ...dont run anymore then 15psi on the stock tubo.
post Sep 11, 2005 - 11:53 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
No worries, I doubt I'll even need to take it to 15lbs.
DEF
post Sep 12, 2005 - 12:20 AM
QUOTE(defgeph @ Sep 11, 2005 - 11:53 PM)
DEF
[right][snapback]333233[/snapback][/right]
trust me, its like a drug. once you get a taste, youll want more and more and more. biggrin.gif
Lo-Fi Version Time is now: February 25th, 2025 - 4:51 AM
