Another 7afte celica, found him on club4ag.com |
Sep 8, 2005 - 2:43 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(celica3000 @ Sep 8, 2005 - 10:59 AM) NIK THE OBX MAKE THE FUEL RAIL TO CELICA ST 1994? [right][snapback]332192[/snapback][/right] if i get a sec i'll call them and 8000rpm redline you can probably disable the rev limit but why do you want to rev to 8000 fro the power is probably more dangerous to unless you build your motor and get some good fuel control for the extra rpms -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 9, 2005 - 1:39 AM |
Enthusiast Joined Sep 7, '05 From LISBON,PORTUGAL Currently Offline Reputation: 4 (100%) |
i have 2 more injectors and injector control unit by tsi and i can reprogram these injectors to get more fuel and the black box(pigi back) have maps to get more fuel in the others 4 injectors.
disable the rev limit as to obtain? -------------------- |
Sep 9, 2005 - 9:13 AM |
QUOTE(celica3000 @ Sep 8, 2005 - 11:39 PM) i have 2 more injectors and injector control unit by tsi and i can reprogram these injectors to get more fuel and the black box(pigi back) have maps to get more fuel in the others 4 injectors. disable the rev limit as to obtain? [right][snapback]332452[/snapback][/right] whats your stock red line mine was like 6200 rpm -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 9, 2005 - 9:41 AM |
mine is 6800 rpm
Sep 9, 2005 - 9:53 AM |
QUOTE(celica3000 @ Sep 9, 2005 - 7:41 AM) mine is 6800 rpm [right][snapback]332498[/snapback][/right] ok so you need to get 1200 more rpm at this point i would go stand alone because your probably going to spend close to the same amount of money on your reprogram ecu as you would a stand alone ecu. But if you still you want to stick with your stock ecu i'm not sure who can do that mod for you. what psi or bar are you running? did you do any mods to your motor or just put the turbo kit on? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 9, 2005 - 10:02 AM |
i just put te turbo and my celica make 0,9 bar=13 or 14 psi
Sep 9, 2005 - 10:26 AM |
QUOTE(celica3000 @ Sep 9, 2005 - 8:02 AM) i just put te turbo and my celica make 0,9 bar=13 or 14 psi [right][snapback]332506[/snapback][/right] have you dynoed your car yet? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 9, 2005 - 10:58 AM |
yes
Sep 9, 2005 - 11:14 AM |
what were the specs from the dyno?
Sep 9, 2005 - 11:15 AM |
i dont remember
Sep 9, 2005 - 11:16 AM |
didn't they make a chart printout for you? Do you have a rough estimate?
Sep 9, 2005 - 11:21 AM |
no
Sep 9, 2005 - 11:24 AM |
do you know your bhp?
Sep 9, 2005 - 11:25 AM |
220hp
Sep 9, 2005 - 11:26 AM |
QUOTE(celica3000 @ Sep 9, 2005 - 9:25 AM) 220hp [right][snapback]332527[/snapback][/right] was that to the wheels? did they give you graph or piece of paper like this This post has been edited by nik: Sep 9, 2005 - 11:38 AM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 9, 2005 - 11:52 AM |
yes but i lost.can i reprogram the ecu ?
the obx make the fuel rail? This post has been edited by celica3000: Sep 9, 2005 - 11:55 AM -------------------- |
Sep 9, 2005 - 12:41 PM |
QUOTE(celica3000 @ Sep 9, 2005 - 9:52 AM) yes but i lost.can i reprogram the ecu ? the obx make the fuel rail? [right][snapback]332531[/snapback][/right] i wrote an email to obx still waiting on a reply as for the ecu i dont know maybe better piggy back that allows you to move the factory rev limit to 8000 not sure if piggy backs can do that -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 9, 2005 - 1:59 PM |
ok nik thanks,and i wait for the obx
Sep 9, 2005 - 4:17 PM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
i dunno about toyotas but i know hondata has a chip s200 that can move rev limit and what not. i know a guy running a 9k redline on his RSX type-s.... and hes s/c, no dyno but he runs a mid-low 13 with major traction issues on stock 05' rims/tires and race gas.. 110 octane
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Sep 9, 2005 - 6:49 PM |
9k is to much for my engine
8k is good not damage the engine i buy a new wheels miglia 17x7 wheels This post has been edited by celica3000: Sep 10, 2005 - 2:53 AM -------------------- |
Lo-Fi Version | Time is now: January 12th, 2025 - 6:23 PM |
