clutch problem |
clutch problem |
Sep 8, 2005 - 7:28 AM |
Enthusiast Joined May 25, '04 From Columbus Ga Currently Offline Reputation: 0 (0%) |
The other day i left my house and my car was driving fine. A few minutes into driving my clutch started acting funny. When i push in the clutch pedal it sort of vibrates and does the same when you release it. When this would happen i couldnt put my car in gear. After a few minutes it would stop and the later it would start again. Now it is completely messed up. I have a mechanic friend and he said to change the master and slave cylinder. I did that and still had the same results. I bled the clutch alot and got it to start working for a while then it messed up again. Has any one had this problem before. Is there a trick to bleeding it other than the normal bleeding procedures. Please help me out.
Sep 8, 2005 - 7:54 AM |
Enthusiast Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
I had a problem with it not getting in gear but it didnt vibrate. Got a new clutch and it was solved the mech told me it was the pressure plate.
Lo-Fi Version | Time is now: November 30th, 2024 - 11:01 AM |
