> Power Steering delete, How to go about it
post Sep 10, 2005 - 12:09 AM
blu94gt
Joined Mar 23, '05
From Kansas City
Ok so I'm looking into removing my power steering pump to reduce that strain on the engine. I can live without power steering, I've driven cars that have been much worse without power steering, I can definitely handle the Celi without it. I know I'll need a shorter belt, which I can do, but I've been looking into what to do with the fluid system. When I had my Prelude, I looked into doing this mod and I had seen a lot of guys had done it to a Prelude and put a breather/snorkel on the fluid line so the fluid wouldn't be under pressure without the pump. Make sense? Is there a mod like this I could be able to do or should I just keep PS and keep saving for my lightened flywheel and clutch lol
1999 Celica GT
post Sep 10, 2005 - 10:16 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
it has it's own belt just cut it.
post Sep 10, 2005 - 10:23 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
isn't the belt also connected to the A/C?
I'd say just get rid of both if you can live with it. I got No P/S and A/C on my, but its pretty easy to drive without P/S......as long as the tires are rotating.
post Sep 11, 2005 - 12:05 AM
MonsterBOX
Joined Jan 8, '05
From Alabama
isnt it supposed to be easier if u remove the pump and drive w/o power steering pump than it is if u turn off the car while driving and try to control the car with a power steering pump?
post Sep 11, 2005 - 12:25 AM
i really cant see this draining much hp from a car. the only time its really working hard is when you are trying to park or at very low speeds. i would just keep it the way it is.
post Sep 11, 2005 - 12:09 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE(soulshadow @ Sep 11, 2005 - 3:23 AM)
[right][snapback]332920[/snapback][/right]
nope the cerp belt does the ac
Lo-Fi Version Time is now: February 25th, 2025 - 6:17 PM
