> 4aghead Question, is it possible?
post Sep 10, 2005 - 2:10 PM
dans_st
Joined May 24, '03
From Andrews TX
Is it possible to do a 4ag (big port) head on a 7afe with the same wiringand map based ECU?
I know that it is better to change out all wiring and ECU, but it it possible to use the wiring that is already there?---the reason I want to do this is I only have my car to drive right now and I drive 20-30min. to work everyday, BUT I think that my 7A head is what is holding be back from getting more power.
Any help and/or even alternative is appreciated- I just need more power.
Also I have just bought and am about to install a b16 manifold w/7a flange,38mm tial wastegate, and a GT3076R ball-bearing turbo.
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Sep 10, 2005 - 3:20 PM
2 optionsL
stand alone ecu.....
or 4a ecu
post Sep 10, 2005 - 4:40 PM
FallenHero
Joined Dec 26, '02
From Alabama
not necessarily... you could have the 7afe ECU re-programed to work a 4ag, but the far less sophisticated answer is the stand alone\ecu swap.
the 7a does, after all, have several sensors etc that the 4ag does not. such as the like... three cam angle sensors. smile.gif
post Sep 11, 2005 - 8:01 AM
Hanyo
Joined Aug 16, '03
From Bay area
hey fallenhero,
does the 4ag have some sensors the 7a doesn't have?
post Sep 12, 2005 - 9:17 AM
nik
Joined Sep 30, '02
QUOTE(playr158 @ Sep 10, 2005 - 1:20 PM)
2 optionsL
or 4a ecu
[right][snapback]332844[/snapback][/right]
option 3
buy a block like i did do the motor on the side until its ready to go in that way you have your car most of the time.
if your on a budget go full 4ag harness i just started out with the bigport head and a AE101 map 4agze harness with dli but soon had to go stand alone it was easier and a little more expensive
or just get a 4ag full harness there on ebay alot the gts change over
post Sep 12, 2005 - 5:40 PM
dans_st
Joined May 24, '03
From Andrews TX
About how much $$ does the total head swap cost?
What I was wanting to do was run the 4A head with the 7A harness and map sensors, without changing any if not much of the electrical in the car and just use the mechanical parts(head, cams, cam gears, ect..) while still running a complete 7A harness,MAP & ECU. and make adjustments for the additional air flow with my SAFC-II.
post Sep 12, 2005 - 5:58 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(dans_st @ Sep 12, 2005 - 10:40 PM)
[right][snapback]333421[/snapback][/right]
What about ignition? ;]
The major difference between the two are the ignition systems. The 7AFE uses a dizzy with an internal coil, while the 4AG uses an external coil. Each are driven slightly different also... gear type versus slot type. If it were easy... people would be doing it left and right... however I will add... do a search for toyotaspeed_90 and read up on his 4AGE swap. He's running a modified 4AFE ecu...
As for costs... the head is rather cheap (25-100 dollars + shipping) but you also gotta consider intake manifold (50-150 dollars), distributor (25-50 dollars), exhaust manifold/header (50-350 dollars), pistons (50-400 dollars)... etc. The 4AG head has a LOT more combustion chamber room... so 7AFE pistons will make like 7 something compression with a 4AG head. If you're planning on going n/a... you have to swap over 4AGE pistons.
post Sep 12, 2005 - 6:15 PM
nik
Joined Sep 30, '02
QUOTE(dans_st @ Sep 12, 2005 - 3:40 PM)
before i answer this are you going n/a or turbo
because if your staying N/A fallen is doing the same might want to talk to him as to how much he has into it
turbo more money
now the route i took is on the spendy side because i upgrade everything
rods=700 turbo=700 stand alone=1500 Head and port work = 1000 turbo manifold+work= 450 injectors=300 there is an idea
This post has been edited by nik: Sep 12, 2005 - 6:17 PM
post Sep 12, 2005 - 6:21 PM
nik
Joined Sep 30, '02
post Sep 13, 2005 - 4:45 PM
dans_st
Joined May 24, '03
From Andrews TX
I already have a turbo on my car and have a tubular B16 manifolf and my JGS flange should be in Friday I have my fuel system set-up with
1.Walbro 255 fuel pump
2.-6 fuel lines from tank
3.Aeromotive FPR
4.RC 550cc injectors
5. Apex-i SAFC II v2
Hopefully this should be more than enough fuel, As far as the external coil I would like to run it - BUT is the 4A a distributor-less ignition system??? I know that IF it is a DIS system there is no way to swap head without harness.
post Sep 13, 2005 - 4:55 PM
nik
Joined Sep 30, '02
QUOTE(dans_st @ Sep 13, 2005 - 2:45 PM)
3.Aeromotive FPR
[right][snapback]333769[/snapback][/right]
the AE101 4agze was DLI and map the 4age red and blue were external coil and afm if you go and look on club4ag.com you'll probably find most of your answers
I'm 99% sure you need to swap harness with the head swap or go standalone the fuel maps on the 7af ecu even with piggy back need alot of fine tuning to get right and the difference in distributors and other sensors save your self a head ace swap harnesses
post Sep 13, 2005 - 5:42 PM
dans_st
Joined May 24, '03
From Andrews TX
Is this a good start?
http://cgi.ebay.com/ebaymotors/Toyota-MR2-...sspagenameZWDVW
post Sep 13, 2005 - 5:51 PM
nik
Joined Sep 30, '02
QUOTE(dans_st @ Sep 13, 2005 - 3:42 PM)
[right][snapback]333797[/snapback][/right]
link doesnt work
post Sep 13, 2005 - 11:15 PM
dans_st
Joined May 24, '03
From Andrews TX
Sorry it is a "Toyota MR2 Cylinder Head 1987 MKI 4AGE AE86" is this a good building block to what I am trying to do?
post Sep 14, 2005 - 12:55 AM
FallenHero
Joined Dec 26, '02
From Alabama
how about go to www.club4ag.com and buy a smallport head and intake manifold off of one of them. Kwanza could probably get you one also... he seems to be able to get most anything. wink.gif
Lo-Fi Version Time is now: November 27th, 2024 - 7:57 AM
