> CAI vs Short ram
post Sep 10, 2005 - 5:24 PM
Vibe
Joined Dec 7, '04
From Antioch, Norcal
I know this has been asked 100 times but I have a short ram on my GT right now and I recently found the How to for a CAI, I was wondering if there was a big enough difference to spend the 40 or whatever for the piping and the time spent installing? Whats the average power gain on a short ram vs a CAI? Any help is appreciated, thanks!
post Sep 10, 2005 - 6:33 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
cais are a few more hp and sound way nicer. Go for the cai.
post Sep 10, 2005 - 6:38 PM
with a short ram...it is STILL in the engine bay sucking in HOT air....thus you might LOSE some horse power...
CAI will suck in COLD AIR since it is OUTSIDE the car = more hp
post Sep 11, 2005 - 1:07 AM
Jaws4God
Joined Mar 27, '04
I was in your boat... had a short ram... but now i just got done installing the Accord 90-93 CAI on my car..
Haven't driven it yet but it should be much better.
post Sep 11, 2005 - 3:06 AM
urbandork
Joined Jul 16, '04
From Los Angeles
also remember that ur stock air box sucks in cold air.
its been shown by dyno that short ram gains about as much hp as a hiflow air box filter does.
Id go with CAI
post Sep 11, 2005 - 3:10 PM
Shigexile
Joined Oct 30, '03
From IL
i don't really trust the filter being there... wouldn't the tires be uncomfortably close to the filter?
post Sep 11, 2005 - 5:37 PM
nope mine is even lower then his...he won't have an issue with it
post Sep 12, 2005 - 10:56 PM
Jaws4God
Joined Mar 27, '04
the inner fender plastic isn't shown in that pic... so its protected from the tire
post Sep 13, 2005 - 5:31 AM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
Well, what about pipes from the CAI? when you drive the car, they become hot too. Doesn't the air get heated up traveling trough it?
post Sep 13, 2005 - 5:39 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
edited*
one question, I have fitted a shortram before but I did not like the sound in the morning(toilet sucking in water).
How would a CAI sound?
This post has been edited by soven: Sep 13, 2005 - 5:41 AM
post Sep 13, 2005 - 6:35 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(Silvan @ Sep 13, 2005 - 3:31 AM)
[right][snapback]333586[/snapback][/right]
if your really crazy about heat. You can buy a special thermal insulation and wrap the pipe. Buts its not worth your time or money.
post Sep 13, 2005 - 4:48 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i got a new version cai, stay tuned for pics..cost is $0 as well.
post Sep 14, 2005 - 9:26 PM
Jaws4God
Joined Mar 27, '04
i've read in a few places that the tubing helps keep heat out... but it will still get hot... but it should be better than the stock air box and a short ram. Its a $35 dollar mod that sounds and looks nice. :-D
post Sep 14, 2005 - 10:51 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
how about keeping the ram and cutting vents on each side of the hood right in front of the filter? like 6" or a foot behind the highbeam.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Sep 15, 2005 - 12:46 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(ArizonaRed @ Sep 15, 2005 - 3:51 AM)
[right][snapback]334368[/snapback][/right]
that sounds like more work, a odd looking hood, possible repaint, and dont forget that ud have to scoop the air in. as hood "vents" vent hot air rather then suck in hot air unless made to do so for another vent in the back to become more efficent.
post Sep 17, 2005 - 11:31 AM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
I recently dropped in a k&n filter on my st, it came with tubing so you could route some outside air directly to the filter element, would this help to eliminate the problem of heat? as the tube runs from the very front of the car by the air dam to the actual filter(a few inches away)
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
post Sep 17, 2005 - 12:12 PM
Shigexile
Joined Oct 30, '03
From IL
i guess so...
post Sep 17, 2005 - 12:13 PM
Shigexile
Joined Oct 30, '03
From IL
my question is, if you have longer piping, wouldn't that make the response of the intake slower -> causing no low-end torque?
post Sep 17, 2005 - 1:16 PM
LewFX
Joined Jan 28, '05
QUOTE(LewFX @ Sep 13, 2005 - 4:48 PM)
[right][snapback]333773[/snapback][/right]
i just eliminated the big box that goes under...the sucks in more air and is filtered out, no more worries of the cai coming loose...its still cold air, not too long and not too short..its purrrrrrfect. i could put a pipe on the end and a filter but now it looks stock and will pass smog inspections too!
post Sep 17, 2005 - 3:25 PM
Vibe
Joined Dec 7, '04
Well I finished the install, pain in the ass but sounds better, feels a lil bit better 'specially on the freeway here are some pics, BTW my engines inbetween coats =)
This post has been edited by Vibe: Sep 17, 2005 - 3:59 PM
Lo-Fi Version Time is now: November 26th, 2024 - 8:49 AM
