big turbo problem, help me out |
Sep 27, 2005 - 3:42 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(StreetRacing10PSI @ Sep 27, 2005 - 11:51 AM) iam having the same problem, white smoke coming out of my exhaust on my 7afte. its not the turbo seals because i just got my turbo rebuilt less then a month ago [right][snapback]338785[/snapback][/right] READ THIS http://www.6gc.net/forums/index.php?showtopic=28840 -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 27, 2005 - 4:53 PM |
Enthusiast Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
[quote=RUNNIN-LOW,Sep 27, 2005 - 11:47 AM]
Doge Posted Sep 23, 2005 - 11:55 AM this problem could be alot more simple than you guys are making it out to be. Just out of curiousity how are you running your pcv, RUNNIN-LOW? are you venting it to atmosphere or are you recirculating it? Do you have anything else recircing to the intake? [/QUOTE] yeah doge im recicing the air back i to the bov. is that what your talking about. i found out the problem already. its like what pressure was telling me too much oil going into the turbo. bought the fittings and bam!! stop smoking..checkd out the head change that in to the trd head gasket. check the turbo in leaks.. figure it was a oil probem so i limited the oil to the turbo and yeah there you go. it stop smoking white stuff..... [right][snapback]338784[/snapback][/right] [/quote] Yeah thats what happened with mine... glad it was as simple as my problem. Have fun with it! |
Sep 27, 2005 - 5:09 PM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
QUOTE(StreetRacing10PSI @ Sep 27, 2005 - 11:51 AM) iam having the same problem, white smoke coming out of my exhaust on my 7afte. its not the turbo seals because i just got my turbo rebuilt less then a month ago [right][snapback]338785[/snapback][/right] do a compresstion and leak down test.. might have ate a piston |
Lo-Fi Version | Time is now: January 10th, 2025 - 1:51 PM |
