The 3SGTE Swap, How-to |
Jul 9, 2006 - 7:11 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
QUOTE(CelicaGT04 @ Jul 9, 2006 - 4:42 PM) [snapback]453785[/snapback] 1. I would like to ask if i can use the 5SFE tranny without having to get a 3SGTE disk with 5SFE splines? 2. Also if i get a 3SGE tranny i would need the 3SGE axels with 5SFE(GT) cables? 3. Did you try to fabricate the 3SGTE wiring harness yourself before sending to DGPerformance? 4.How much was the cost for the harness to be completed? 5. Did you have to remove your 5SFE harness to send? or did you send the one that came with your clip (If applicable)? 1. Could you do it ? sure. I WILL NOT recommend doing it that way. The right way is get a 3sgte disk and matching the splines with a 5sfe tranny. 2. If you have a gt already I wouldnt bother getting a tranny. But if you do buy one, yes is my answer to number 2. I have not tryed driving my car with GT axles. I know they fit, but I dont know if they would work. 3. No, sent everything to him. He's awesome at wiring ! 4. I cant remember, sorry. 5. You have to send him both harnesses, ST or GT. And the harness from your clip. You will also need to send him the fuel pump relay, located in the engine bay from the clip. This relay would be in a black box bolted to the frame next to the AC compressor. GL DEF -------------------- I will return one day. |
Jul 9, 2006 - 7:57 PM |
Enthusiast Joined Nov 22, '05 From Mesquite, Texas Currently Offline Reputation: 0 (50%) |
Awesome, thanks for the quick reply! I will try to get in touch with DG soon so i can talk to him about cost and time. Thanks!
Jul 25, 2006 - 9:33 AM |
Enthusiast Joined Jul 23, '06 From north bennington vermont Currently Offline Reputation: 0 (0%) |
this is a great thread how can you put the all track tranny in the st ? im totaly lost i thought that demands power from all wheels?
Jul 25, 2006 - 9:55 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Unless you convert it to FWD. Can be done but you also need parts from another tranny.
-------------------- JDM Powerplant installed, BPU coming very soon!
Oct 31, 2006 - 7:17 AM |
Enthusiast Joined Mar 30, '05 From Wisconsin Currently Offline Reputation: 0 (0%) |
i NEED to know 2nd genration of 3sge tranny, i did a swap but i was using the all track stage 3 clutch.. when i match the tranny pine core of 3sge and 3sgte tranny, they both have differen pine core for the clutch, 3sge pine core is small then 3sgte..
but i like to know where i can find the right clutch to fit my 3sge tranny... cuz the flywheel is little small then the 3sgte tranny.. HOW CAN I FIND A CLUTCH THAT 2ND GENRATION OF 3SGTE TRANNY.. CAN YOU PLZ HELP ME PLZ..?? THANK FOR UR TIME!! |
Feb 22, 2007 - 1:02 AM |
Enthusiast Joined Dec 3, '05 From San Jose, CA Currently Offline Reputation: 0 (0%) |
so the 3sge tranny bolts right up just like the 5sfe tranny? theyre so hard to come across tho, unless im searchin the wrong sites...i cant seem to find one. whats the name of the 3sge tranny? i know the gt is like an s54, but whats the 3sge? iono what to type in when i search
Feb 22, 2007 - 6:43 AM |
Enthusiast Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
awesome dude awesome thread!! really glad you posted this because i was looking to do this in a few months (come summer..) Please ask if Christian will move this to the How-To-Articles!
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Feb 22, 2007 - 11:56 AM |
Enthusiast Joined Oct 3, '02 From HOUSTON Currently Offline Reputation: 0 (0%) |
its in the stickies homie
Feb 22, 2007 - 12:51 PM |
QUOTE(hashmaster52 @ Feb 22, 2007 - 1:02 AM) [snapback]529254[/snapback] so the 3sge tranny bolts right up just like the 5sfe tranny? theyre so hard to come across tho, unless im searchin the wrong sites...i cant seem to find one. whats the name of the 3sge tranny? i know the gt is like an s54, but whats the 3sge? iono what to type in when i search Might want to try searching JDM S54, or 3sge transmission. -------------------- I will return one day. |
Feb 22, 2007 - 1:48 PM |
QUOTE(defgeph @ Feb 22, 2007 - 12:51 PM) [snapback]529362[/snapback] QUOTE(hashmaster52 @ Feb 22, 2007 - 1:02 AM) [snapback]529254[/snapback] so the 3sge tranny bolts right up just like the 5sfe tranny? theyre so hard to come across tho, unless im searchin the wrong sites...i cant seem to find one. whats the name of the 3sge tranny? i know the gt is like an s54, but whats the 3sge? iono what to type in when i search Might want to try searching JDM S54, or 3sge transmission. ooooh...so i guess the 3sge tranny is just a jdm version of the gt or somethin...thx |
Feb 22, 2007 - 9:39 PM |
QUOTE(defgeph @ Feb 22, 2007 - 12:51 PM) [snapback]529362[/snapback] QUOTE(hashmaster52 @ Feb 22, 2007 - 1:02 AM) [snapback]529254[/snapback] so the 3sge tranny bolts right up just like the 5sfe tranny? theyre so hard to come across tho, unless im searchin the wrong sites...i cant seem to find one. whats the name of the 3sge tranny? i know the gt is like an s54, but whats the 3sge? iono what to type in when i search Might want to try searching JDM S54, or 3sge transmission. well i searched a bunch of places n no luck.....anybody have any links to where i can find a tranny for the 3s swap (preferably a 3sge tranny, but e153 will do as well)? thx |
Feb 23, 2007 - 1:01 PM |
as far as most people can tell the 3sge and gt tranny are exactly the same, just check out your local yards to find a gt tranny
Feb 23, 2007 - 5:57 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(quicknstyle @ Feb 23, 2007 - 10:01 AM) [snapback]529681[/snapback] as far as most people can tell the 3sge and gt tranny are exactly the same, just check out your local yards to find a gt tranny -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Feb 23, 2007 - 10:16 PM |
Enthusiast Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
QUOTE(phattyduck @ Feb 23, 2007 - 3:57 PM) [snapback]529743[/snapback] QUOTE(quicknstyle @ Feb 23, 2007 - 10:01 AM) [snapback]529681[/snapback] as far as most people can tell the 3sge and gt tranny are exactly the same, just check out your local yards to find a gt tranny -Charlie correct, same tranny, just different final drives S54: 3.285, 1.960, 1.322, 1.028, 0.820 / FD: 3.944, 4.176 -3.944 diff found in jdm/uk 2nd and 3rd gen 3sge -4.176 diff found in mk2 mr2 NA and 6gc GT -------------------- I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Feb 24, 2007 - 11:44 AM |
QUOTE(celicaST @ Feb 23, 2007 - 10:16 PM) [snapback]529801[/snapback] QUOTE(phattyduck @ Feb 23, 2007 - 3:57 PM) [snapback]529743[/snapback] QUOTE(quicknstyle @ Feb 23, 2007 - 10:01 AM) [snapback]529681[/snapback] as far as most people can tell the 3sge and gt tranny are exactly the same, just check out your local yards to find a gt tranny -Charlie correct, same tranny, just different final drives S54: 3.285, 1.960, 1.322, 1.028, 0.820 / FD: 3.944, 4.176 -3.944 diff found in jdm/uk 2nd and 3rd gen 3sge -4.176 diff found in mk2 mr2 NA and 6gc GT sry, but what exactly does that mean? |
Feb 26, 2007 - 5:08 PM |
Enthusiast Joined Aug 2, '05 From ohio Currently Offline Reputation: 0 (0%) |
so i need a little of help selling my 97 st but im putting a new motor in for him and i was looking at getting a 3sge clip from a mr2 and was wondering if i can do this or will i need a clip from another celica because of the mounting. im getting it from a mr2 beacuse that will be my next car so i can part the rest of it out and turbo it.
Feb 26, 2007 - 6:31 PM |
You would need to rewire a harness, fab some GT engine mounts, new trans. mounts. etc. If you want to put a newer engine into your ST I would suggest you find an "A" series engine, not an "S" series. Something like a 4AGE from a MKI MR2 or an AE92 Corolla GT-S. Also a Silvertop 4AGE from overseas would be good. If you are lucky you might be able to find a 4A-GZE from a MKI MR2, I believe starting in 1988.
Feb 27, 2007 - 3:45 PM |
so its pretty useless to try and put a 3sge in it?
Feb 27, 2007 - 5:36 PM |
its not "useless", it just isn't cost effective if you are looking to sell it. You won't get nearly as much $ back as you put into it.
Oct 27, 2007 - 8:42 PM |
Enthusiast Joined May 11, '06 From MD Currently Offline Reputation: 0 (0%) |
amazing post... i think because of this im going to go ahead and try this..... 2 questions how does the car feel, easy to drive or does torque steer make it difficult and where do you think i could get a good deal on a good clip
Lo-Fi Version | Time is now: November 27th, 2024 - 1:16 AM |
