still getting the shake at higher speeds.. |
Sep 12, 2005 - 3:52 PM |
Ok.. well I did the brakes, new rotors, new stuf and alignment, It seems to drive a lot better and brake. But I still get the shakes going above 65-70. Im thinking its probley the wheel baring but would that cause it. Also when in the air, the wheel moves a bit, like if i hold the top and bottom theres some play when all the lugs are completley tight. Any other ideas?
Thanks doug |
Sep 12, 2005 - 4:00 PM |
sounds like bearings to me
Sep 13, 2005 - 9:49 AM |
Enthusiast Joined May 3, '04 From pittsburgh Currently Offline Reputation: 0 (0%) |
QUOTE(LewFX @ Sep 12, 2005 - 9:00 PM) sounds like bearings to me [right][snapback]333394[/snapback][/right] ditto..and thats not good, as you prob know..get that checked soon before your wheels falls off -------------------- Now SR powered |
Sep 13, 2005 - 10:50 AM |
QUOTE(OrbitalGT95 @ Sep 13, 2005 - 9:49 AM) QUOTE(LewFX @ Sep 12, 2005 - 9:00 PM) sounds like bearings to me [right][snapback]333394[/snapback][/right] ditto..and thats not good, as you prob know..get that checked soon before your wheels falls off [right][snapback]333629[/snapback][/right] There not going to fall off, but they could lock up, which is just as bad. Im gunna check it an replace if needed fri or sat. |
Sep 13, 2005 - 3:08 PM |
Could be something simpler -- have you checked the wheels are correctly balanced?
Sep 14, 2005 - 10:22 PM |
Enthusiast Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
i would say balance to toyota did that to mine before didnt balance my tires right. check it first and is it the steering wheel or the car shaking. my steering wheel started to shake
This post has been edited by cyb593: Sep 14, 2005 - 10:25 PM |
Sep 15, 2005 - 12:07 PM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
I would check in this order -
bent rim - check the inside as it`s weaker than the outside of the alloy and more prone to bending. Bearings - simple check - jack car up, waggle top/bottom. if it moves your bearings are fubar. Balanced tyres |
Sep 15, 2005 - 12:48 PM |
Enthusiast Joined Oct 3, '02 From bonzaisushi@hotmail.com Currently Offline Reputation: 0 (0%) |
make sure your lug nuts are tight.
Sep 15, 2005 - 2:53 PM |
Enthusiast Joined Oct 2, '03 Currently Offline Reputation: 0 (0%) |
check your tire pressure. I was having the same problem and I just filled them up to the max lbs on the tire.
Sep 15, 2005 - 10:17 PM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
what kind of tires do you have? maybe a better tire would help also. i had the same problem, but my rim was bent its a good thing i had an extra set laying around
Sep 15, 2005 - 10:43 PM |
Im pretty sure its the bareings.. cause they wiggle or what ever when its jaked up a bit, and def feels dif then the wheels not being balanced, and there good year tires, so good plain wheels.
I might get time to chech it out right. Has any one ever replace dbareings on the celi? I have on my bros rover, but that seems much dif. How hard how long? |
Sep 16, 2005 - 1:07 PM |
Replaced the rear bearings on my`n not 2 weeks ago although might be slightly different for your car, I needed a 2 tonne press to get them back in, pain in the arse...took 3 hours to do, never ever again.
Sep 16, 2005 - 4:44 PM |
If your wheels seem to shake in mid air its probbaly your tie rods going out the window. Thats the only real explaination in wheels that shake when everything else is perfectly fine.
Sep 18, 2005 - 12:05 AM |
could be the belts in the tires also they could be seperating... happened to my brothers camry. it just acted like it was limping?? so when u got to about 50 it started to even out and drive pretty smooth. coule do the opposite just trying to give u something to ponder. by the way how much is it does anyone know to get wheel bearings replaced??
This post has been edited by cyb593: Sep 18, 2005 - 12:07 AM |
Sep 18, 2005 - 2:31 PM |
Enthusiast Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
Do this: Grab the wheel by the top and bottom (while lifted) and try to move one arm back and the other forward, typically this is a good way of testing wheel bearings, grab it by the sides and wiggle it, typically this indicates a bad tie rod. also roll the tire while in mid air to see if the rim may be bent. if its a bad bearing it'll prolly make a sound at just about any speed, so you might wanna observe that as well
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." |
Lo-Fi Version | Time is now: November 27th, 2024 - 4:40 PM |
