Drums on the GT |
Drums on the GT |
Sep 12, 2005 - 7:56 PM |
Enthusiast Joined Sep 27, '04 From Minnesota Currently Offline Reputation: 0 (0%) |
To all the US GT owners. Do you people ever have to change your drum brakes?
Sep 12, 2005 - 8:11 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
the GTs come with all 4 disk brakes. the STs come with the rear drums.
Sep 12, 2005 - 8:17 PM |
No. The GT does come with drums.
Sep 12, 2005 - 8:21 PM |
QUOTE The braking system on the two models is different as well. The GT model has four wheel disk brakes, with ventilated rotors up front and solid rotors on the rear. The ST model has ventilated disk brakes up front, but has rear drum brakes, which don't perform as well. Both models are available with ABS as an option. http://www.6gc.net/index.php?action=information&itu=4 -------------------- |
Sep 12, 2005 - 8:28 PM |
what? Gt with drums. Perhaps you bought a car that was slapped with GT on it.
If it don't have a moonfoof, S-series engine and OEM style sturt bars in the engine bay. Then you deff. have an ST.(period) |
Sep 12, 2005 - 8:29 PM |
What does the ebrake use? I know for sure it aint the rear pads.
Sep 12, 2005 - 8:44 PM |
I'll take some pics tomorrow of my GT. Yes, it is a GT and it does have 4 wheel disc brakes. But it also has, what looks to me, drum brakes. Now, if its called something else please do let me know. They just look like drums to me.
Sep 12, 2005 - 8:59 PM |
QUOTE(pokemeintheeye @ Sep 12, 2005 - 8:44 PM) I'll take some pics tomorrow of my GT. Yes, it is a GT and it does have 4 wheel disc brakes. But it also has, what looks to me, drum brakes. Now, if its called something else please do let me know. They just look like drums to me. [right][snapback]333478[/snapback][/right] Well its 4 wheel disc, but also yes does have "mini" drums.. or what not for the parking brake. |
Sep 12, 2005 - 9:02 PM |
The ST204 parking brake does indeed use a drum-based braking system. Notice how the rear rotor on your guys' GTs is so big in the middle? That's because the inside of it is like a drum. It makes contact with shoes internally when the e-brake is engaged.
I believe I read somewhere that only the dealer carries shoes for the rear e-brake assembly, and they cost around $80. I dunno how correct that is though. -------------------- New Toyota project coming soon...
Sep 13, 2005 - 7:29 AM |
QUOTE(Coomer @ Sep 12, 2005 - 7:02 PM) The ST204 parking brake does indeed use a drum-based braking system. Notice how the rear rotor on your guys' GTs is so big in the middle? That's because the inside of it is like a drum. It makes contact with shoes internally when the e-brake is engaged. I believe I read somewhere that only the dealer carries shoes for the rear e-brake assembly, and they cost around $80. I dunno how correct that is though. [right][snapback]333484[/snapback][/right] your right. your local chain store would not carry them. But you can send them in to get rebuilt. (they add more brake material) |
Sep 13, 2005 - 9:22 AM |
the shoes are prolly 20$ ea for each shoe.
both sides tend to not wear evenly, so you may wanna check them and just get the ones that you need. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 13, 2005 - 12:50 PM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
QUOTE(soulshadow @ Sep 12, 2005 - 8:28 PM) what? Gt with drums. Perhaps you bought a car that was slapped with GT on it. If it don't have a moonfoof, S-series engine and OEM style sturt bars in the engine bay. Then you deff. have an ST.(period) [right][snapback]333472[/snapback][/right] I don't have a moonroof kinda miss it though... -------------------- 1999 Celica GT
Sep 13, 2005 - 3:44 PM |
QUOTE(Coomer @ Sep 13, 2005 - 2:02 AM) I believe I read somewhere that only the dealer carries shoes for the rear e-brake assembly, and they cost around $80. I dunno how correct that is though. [right][snapback]333484[/snapback][/right] Are you serious? Damn, that sucks. Cause I really need to change mine. The ebrake doesn't hold anymore. All the parts stores has the GT and ST shoes listed as the same. Thats what they tell me. I guess I'll have to try it anyways and see what happens. It it doesn't work then I'll have to take it to the Toyota dealer. |
Sep 13, 2005 - 3:46 PM |
Ohh.. And I didn't take any pics. Today just didn't look like a nice day and with the mist. I didn't really wanna sit there and get wet slowly while the wind was blowing. Its a little chilli out.
Sep 13, 2005 - 4:25 PM |
Could it be just a matter of adjusting your brakes or the handle? I mean, what is the condition of the friction material.
Sep 13, 2005 - 4:41 PM |
No. You can't just adjust it. If your shoes are worn out your brakes won't work. Just like your pads. If they wear out they don't work. Then you risk damaging your disc's and your calipers.
My ebrake only holds on small inclines. It'll roll in steeper hills. |
Sep 13, 2005 - 5:42 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
Only the dealer carries the shoes. In canada they go for $35 a shoe. Thats $70 each side. You should never have to change these, if you do you might have a sticky ebrake cable.
Sep 13, 2005 - 6:57 PM |
Poke, you'll note the dual nature of my query: condition of the friction material (aka are the shoes worn out) or correction of the position. I thought it was obvious enough not to specify that adjusting would only apply to shoes with sufficient material left.
Sep 14, 2005 - 8:19 AM |
You can adjust the ebrake cable. GT's have disk brakes on all 4 ends. Yes the ebrake uses the insides of the disks...
Sep 14, 2005 - 2:45 PM |
Enthusiast Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
id be surprised if those thing wear out before 200,000km.... er 130,000 miles.
unless you drive with your e-brake on. |
Lo-Fi Version | Time is now: December 4th, 2024 - 5:17 AM |
