3SGTE Turbo Pressure Sensor, Resistance |
Sep 13, 2005 - 7:46 PM |
Anyone with a swapped 3SGTE want to measure the resistance across the terminals of their Turbo Pressure Sensor a.k.a. Boost Pressure Sensor? Readings would need to be from the sensor itself with the engine off and no vacuum applied to the sensor.
Already tried the BGB. No mention of the resistance there. Just voltage readings which won't quite work for what I need. -------------------- Project ST204.5 99.88946% complete... |
Sep 13, 2005 - 7:49 PM |
try this site... its got a lot of really techy info on all the toyota sensors, that the bgb dosnt cover
http://www.autoshop101.com/autoshop15.html -------------------- 15PSI - 30MPG - Megasquirt Tuned
Sep 14, 2005 - 3:01 PM |
Thanks Lagos. That's some really good reading. However, I couldn't find what I was looking for.
Luckily someone at alltrac.net had what I was looking for: 5.52k ohms. -------------------- Project ST204.5 99.88946% complete... |
Lo-Fi Version | Time is now: January 12th, 2025 - 2:06 PM |
