7afe headers, true or false |
Sep 14, 2005 - 7:50 PM |
Enthusiast Joined Aug 30, '02 From NYC Currently Offline Reputation: 0 (0%) |
true or false
any corrolla 7afe performance header will fit a 6th gen st? the head bolts on perfectly, the only thing is that you need to extend the downpipe thanks |
Sep 14, 2005 - 7:56 PM |
Enthusiast Joined Feb 20, '03 From Dayton, OH Currently Offline Reputation: 0 (0%) |
True!
But I think the O2 sensor needs to be custom fit. |
Sep 14, 2005 - 8:18 PM |
QUOTE(celica_st95 @ Sep 14, 2005 - 5:56 PM) True! But I think the O2 sensor needs to be custom fit. [right][snapback]334269[/snapback][/right] cool with that said, what company makes a corrolla header? is the corrolla a 1.6liter?? thanks |
by the way is it the 93-99 corrollas
Sep 14, 2005 - 8:46 PM |
its the 93-97 corolla 1.8, just like the ST
13.6@108MPH, 5SFTE Powered |
Sep 14, 2005 - 10:55 PM |
Enthusiast Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) |
sold on ebay 180-250 bucks after shipping
-------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
Sep 14, 2005 - 11:34 PM |
not just the o2 sensor
but you also need an extension for the downpipe |
Sep 14, 2005 - 11:40 PM |
QUOTE(playr158 @ Sep 14, 2005 - 9:34 PM) not just the o2 sensor but you also need an extension for the downpipe [right][snapback]334390[/snapback][/right] which any muffler shop can do for like... $20. |
Sep 15, 2005 - 9:47 AM |
Enthusiast Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
yah i've have my 1.8L Corolla Header under my bed for about 4... 5 months now i had money then (prior to girlfriend) and i've been slowly collecting money to do it. fyi this is illegal to do, i've gone to many shops to get an estimate, turned away by 3 out of 5. because it eliminates the cattalitic converter.... hmmm yahh... :-/
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Sep 15, 2005 - 2:51 PM |
this defenitly shouldn't eliminate the cat......
UNLESS......your obd1 with 2 cats.....manifold cat and under car cat... even with just your under car cat you should be fine |
Sep 15, 2005 - 8:02 PM |
Enthusiast Joined Sep 1, '04 From Ohio Currently Offline Reputation: 0 (0%) |
has anyone tried a honda b-series header???
Sep 15, 2005 - 8:03 PM |
If replacing the stock manifold with a tubular header eliminates the cat, then just install a second cat under the body. All Celicas, whether they had one cat (by the manifold) or two (manifold and underbody) had a resonator. You can replace that resonator -- use a catalytic converter with a resonated core like the Car Sound 9440x series, and you get to keep sound suppression and clean emissions, without having to rebuild a large portion of your exhaust.
Sep 15, 2005 - 11:07 PM |
QUOTE(CelicaST18 @ Sep 15, 2005 - 8:02 PM) has anyone tried a honda b-series header??? [right][snapback]334744[/snapback][/right] i would like to know your reasoning for this statement... if its because you've read NIK, myself, fallen and a few other members talking about a B16 TURBO manifold then you need to realize an N/A HEADER is different from a TURBO MANIFOLD... a B16 header will not work.... also why get a honda header and spend more to modify and make it fit then to buy one that is built for the motor and get an adapter? |
Sep 16, 2005 - 12:32 PM |
Enthusiast Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
pace setter
part number 70-1151 93-97 Corolla, 1.8L/7AFE $249.95 -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 8:48 AM |
