> Car wont start!, My starter won't run???
post Sep 15, 2005 - 11:03 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Ok heres my problem. When I turn the key in my car. My COR will make a clicking noise, but my starter won't start. The last time I got it to run was before I put in my downpipe to the engine. I hooked up the O2 sensor wire to the engine and started it up and it ran, but since the pipe was leaking gas at the headers I took off the downpipe and it accidently just ploped to the ground with the wires still attached to it. Then after that I went and installed my throttle cable taking out the old one and the cruise control throttle cable so that I can put in the new one that was longer for my 4age engine. Then I tried to start it, but nothing happens!! What went wrong? I checked all the wires and everything was fine. Could it be the starter? I checked it too with a volt-meter and it was ok. Im so confused trying to get that P.O.S to work now.. I NEED HELP!!! confused.gif
post Sep 16, 2005 - 9:29 AM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Check the battery terminals first and clean them good. If that doesn't help and the mulitmeter reads like 12 volts or more starter is toast.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
Lo-Fi Version Time is now: February 25th, 2025 - 10:17 AM
