![]() Enthusiast ![]() ![]() ![]() Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) ![]() |
ok, so i took my 7afTe to get dynoed today and was VERY unhappy with the results. at 8PSI it pulled a 93.5HP and 97.7Ft-lbs torque. thats less then stock!!! i have no clue what is wrong with my car. its def getting boost too because from 3-5 k u can feel it pull and then letting off the gas the BOV goes off. so i Have no clue what is wrong. if u have any idea whats goin on let me know. right now iam goin out to look at SRT-4s cuz i want a second car, this car just aint doin it for me.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(StreetRacing10PSI @ Sep 16, 2005 - 9:34 AM) ok, so i took my 7afTe to get dynoed today and was VERY unhappy with the results. at 8PSI it pulled a 93.5HP and 97.7Ft-lbs torque. thats less then stock!!! i have no clue what is wrong with my car. its def getting boost too because from 3-5 k u can feel it pull and then letting off the gas the BOV goes off. so i Have no clue what is wrong. if u have any idea whats goin on let me know. right now iam goin out to look at SRT-4s cuz i want a second car, this car just aint doin it for me. [right][snapback]334956[/snapback][/right] u just made me not want to turbo my car, iknew the turbo would end up doing sh!t ne way on a 7afe -------------------- ![]() |
sounds like you have a MAJOR problem, like a boost leak, or somthing.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
Yeah something isn't right.... You should go and re-check everything
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
QUOTE(StreetRacing10PSI @ Sep 16, 2005 - 9:34 AM) ok, so i took my 7afTe to get dynoed today and was VERY unhappy with the results. at 8PSI it pulled a 93.5HP and 97.7Ft-lbs torque. thats less then stock!!! i have no clue what is wrong with my car. its def getting boost too because from 3-5 k u can feel it pull and then letting off the gas the BOV goes off. so i Have no clue what is wrong. if u have any idea whats goin on let me know. right now iam goin out to look at SRT-4s cuz i want a second car, this car just aint doin it for me. [right][snapback]334956[/snapback][/right] THERE IS NO WAY YOU SHOULD BE MAKING THAT LITTLE POWER ON 8 LBS ok first check all connectors then check the pipe right below the turbo it has a little metal nipple make sure there is a rubber cap on it. i just dont understand something is wrong i dyno tested that hole kit kit 3 times and 3 runs each time take detailed pictures of everything also check to make sure all the bolts on the turbo housing are tight edit: those numbers should be your stock whp almost seems like a pipe might be loose between the intercooler to the TB or a massive boost leak recheck the everything from manifold bolts to vacum line connection can you put up the DYNO chart so i can look at it I mean at only 4.5 psi i made 126.95 whp and 162.03 torque This post has been edited by nik: Sep 16, 2005 - 1:04 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) ![]() |
reset your ecu?
![]() Enthusiast ![]() ![]() ![]() Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(SoundSlut_dotcom @ Sep 16, 2005 - 4:39 PM) u just made me not want to turbo my car, iknew the turbo would end up doing sh!t ne way on a 7afe [right][snapback]334957[/snapback][/right] No, a turbo would work on a 7afe. As long as it's installed right it will work. He's just having a difficulty, but I'm sure he''l find the problem soon then it will be awesome! -------------------- ![]() CLOSED on 25 acres! -shop coming soon.... |
QUOTE(nik @ Sep 16, 2005 - 1:57 PM) QUOTE(StreetRacing10PSI @ Sep 16, 2005 - 9:34 AM) ok, so i took my 7afTe to get dynoed today and was VERY unhappy with the results. at 8PSI it pulled a 93.5HP and 97.7Ft-lbs torque. thats less then stock!!! i have no clue what is wrong with my car. its def getting boost too because from 3-5 k u can feel it pull and then letting off the gas the BOV goes off. so i Have no clue what is wrong. if u have any idea whats goin on let me know. right now iam goin out to look at SRT-4s cuz i want a second car, this car just aint doin it for me. [right][snapback]334956[/snapback][/right] THERE IS NO WAY YOU SHOULD BE MAKING THAT LITTLE POWER ON 8 LBS ok first check all connectors then check the pipe right below the turbo it has a little metal nipple make sure there is a rubber cap on it. i just dont understand something is wrong i dyno tested that hole kit kit 3 times and 3 runs each time take detailed pictures of everything also check to make sure all the bolts on the turbo housing are tight edit: those numbers should be your stock whp almost seems like a pipe might be loose between the intercooler to the TB or a massive boost leak recheck the everything from manifold bolts to vacum line connection can you put up the DYNO chart so i can look at it I mean at only 4.5 psi i made 126.95 whp and 162.03 torque [right][snapback]334978[/snapback][/right] Their is no rubber cap on the nipple, i dnt think their ever was either. iam goin to try and find somin that will fit on their and see if that helps |
QUOTE(Jdog1385 @ Sep 16, 2005 - 1:53 PM) reset your ecu? [right][snapback]335001[/snapback][/right] aw man that response makes me wanna smack my head against a wall.... what made you say that........... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
QUOTE(playr158 @ Sep 16, 2005 - 3:46 PM) makes me wanna smack my head against a wall.... [right][snapback]335021[/snapback][/right] how bout i do it for you? ![]() |
hey do you have a cell phone version or cinglar STREETRacing10psi
QUOTE(nik @ Sep 16, 2005 - 4:07 PM) hey do you have a cell phone version or cinglar STREETRacing10psi [right][snapback]335032[/snapback][/right] Yea i have verison Pm me for the # if u want, but i think i found out the problem. i took out my spark plug wires and the 1st and 2nd 1's are completly shot. these wires are new too and cost me $130.00. i took them out and they completly fell abart into 4 pieces. thats probly the problem cuz if it was runnin on 2 pistons then 1/2 the power would only b around 90HP any way. iam goin to go out now and buy new stock wires for now and see if thats the problem. |
QUOTE aw man that response makes me wanna smack my head against a wall.... what made you say that........... lol, i was joking but on a serious note my buddy had a problem with his ecu and it was restricting horsepower |
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
just for ****s and giggles its verizon and cingular
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
QUOTE(celicast3sgte @ Sep 16, 2005 - 2:48 PM) just for ****s and giggles its verizon and cingular [right][snapback]335079[/snapback][/right] yeah i suck at spelling ![]() This post has been edited by nik: Sep 16, 2005 - 5:16 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
QUOTE(StreetRacing10PSI @ Sep 16, 2005 - 1:44 PM) QUOTE(nik @ Sep 16, 2005 - 4:07 PM) hey do you have a cell phone version or cinglar STREETRacing10psi [right][snapback]335032[/snapback][/right] Yea i have verison Pm me for the # if u want, but i think i found out the problem. i took out my spark plug wires and the 1st and 2nd 1's are completly shot. these wires are new too and cost me $130.00. i took them out and they completly fell abart into 4 pieces. thats probly the problem cuz if it was runnin on 2 pistons then 1/2 the power would only b around 90HP any way. iam goin to go out now and buy new stock wires for now and see if thats the problem. [right][snapback]335049[/snapback][/right] my girls got verison but anyways did those new wires fix your problem? -------------------- yea your 3sgte is cool but ill stick to my 7agte
note, the MR2 very high HP guys will tell you "always use OEM Toyota plug wires"
no jive -------------------- |
i replaced the wires and brought it to the track and at 8psi ran a pathetic 17.770 so the car seems like it is still around 90 HP
Edit: my second run was a 22.8 cuz my car wouldnt shift into 3rd gear on the automatic and it started to miss fire. ended up that a spark plug wire was loose but the car still seems the same. i even cloged the hole one the IC piping. Still have no clue whats goin on This post has been edited by StreetRacing10PSI: Sep 16, 2005 - 11:31 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(Batman722 @ Sep 17, 2005 - 3:19 AM) note, the MR2 very high HP guys will tell you "always use OEM Toyota plug wires" no jive [right][snapback]335222[/snapback][/right] I used to have aftermarket wires, i was recommended to go back to oem by my mechanics. QUOTE(StreetRacing10PSI @ Sep 17, 2005 - 4:20 AM) i replaced the wires and brought it to the track and at 8psi ran a pathetic 17.770 so the car seems like it is still around 90 HP Edit: my second run was a 22.8 cuz my car wouldnt shift into 3rd gear on the automatic and it started to miss fire. ended up that a spark plug wire was loose but the car still seems the same. i even cloged the hole one the IC piping. Still have no clue whats goin on [right][snapback]335250[/snapback][/right] Do you have a kit from Nik? Is it the same that hes got? I'd just check everything one by one. fuel problem, intake clog, exhaust restriction. -------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) ![]() |
hmmm very strange... i hope u find the problem asap. like nik said... the 7afe has potential when a turbo is slapped on it, its just that theres prolly something going on that u havent come across yet. anyway goodluck!
bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Lo-Fi Version | Time is now: February 21st, 2025 - 2:03 PM |
