3 Pages V  < 1 2 3 >
> Very upset, dyno results
post Sep 17, 2005 - 4:28 AM
Hanyo
Joined Aug 16, '03
From Bay area
another auto 7afte, how is the tranny holding up, and why would it not shift.
Post your air fuel mixture chart for us, maybe its leaning out?
post Sep 17, 2005 - 10:49 AM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
QUOTE(Hanyo @ Sep 17, 2005 - 5:28 AM)
[right][snapback]335320[/snapback][/right]
i set up the safc2 to runn a little more rich and still no change. iam goin to take apart the IC piping make sure nuttins wrong, set the boost a lil higher buy a new boost guage and see what happens.
post Sep 18, 2005 - 12:57 AM
i replaced the wires and brought it to the track and at 8psi ran a pathetic 17.770 so the car seems like it is still around 90 HP
MWAHAHAHAHAHAHHA i'm faster with my N.A manual 7afe wink.gif biggrin.gif biggrin.gif
post Sep 18, 2005 - 2:42 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i eliminated all the problems and the only thing it could b is the waste gate. other then that everything is fine. my boost quage is still reading 15lbs vacume at idle and 0lbs boost at full throttle.
post Sep 18, 2005 - 2:48 PM
QUOTE(StreetRacing10PSI @ Sep 18, 2005 - 3:42 PM)
[right][snapback]335689[/snapback][/right]
if your only reading 15inmg then you have a vac leak
it should be 18-22inhg.
post Sep 18, 2005 - 2:49 PM
QUOTE(StreetRacing10PSI @ Sep 18, 2005 - 2:42 PM)
i thought you said it was at 8psi in your 1st post?
post Sep 18, 2005 - 3:05 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
were the waste gate is it should b at 8lbs. with the wastegate were its at it pulled off a 93hp on the dyno, with the waste gate open it allmost seems like it barley moves
post Sep 19, 2005 - 7:23 AM
boosted_K2
Joined Aug 30, '02
From Michigan
if you are having engine problems and something is wrong.... the absolute stupidest thing you can ever do is add MORE boost...
No but I don't buy it
Cause I'm...
post Sep 19, 2005 - 9:39 AM
nik
Joined Sep 30, '02
QUOTE(StreetRacing10PSI @ Sep 18, 2005 - 1:05 PM)
[right][snapback]335701[/snapback][/right]
add a manual boost controller i never ran that setup off the waste gate you can but to be safe get a controller and start and 4 psi check the boost gauge and hook up your lines like this
edit:
ok sorry that i wasnt detailed about it but here i'll break it down a little
map sensor line ( dont split off)
FMU or boost controllers ( the first black T is for my FMU and the second T white is for my greddy Profec E-01)
boost gauge and or bov (the line coming up over the TB is off the big line in the middle back of the manifold) look close
here a close up
all these pics are in the how to but i just need to rewrite the how to to be more detailed hope this helps
This post has been edited by nik: Sep 19, 2005 - 9:40 AM
post Sep 20, 2005 - 5:30 PM
nik
Joined Sep 30, '02
get one of these manual boost controllers.If you have checked all the connections and everything is tight and the hole is caped off its got to be the wastegate so get on ebay or borrow one from a friend.And keep me up dated
post Sep 20, 2005 - 8:12 PM
soltrain
Joined Aug 19, '04
From Berkeley
damn, nik's got some good advice
post Sep 20, 2005 - 9:40 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
and some good money! I want a turbo! Nik, sell me your 7A-GTE engine.. and then install it...smile.gif
**** Photobucket
post Sep 21, 2005 - 9:43 AM
nik
Joined Sep 30, '02
QUOTE(95CelicaST @ Sep 20, 2005 - 7:40 PM)
[right][snapback]336710[/snapback][/right]
I have 4 times the money into my 7agte than i did on my 7afte but i learned alot on my 7afte project and even more on my 7agte project
you'll want this motor even more when you see the numbers wink.gif it puts down
edit: any update street?
This post has been edited by nik: Sep 21, 2005 - 9:44 AM
post Sep 23, 2005 - 11:53 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
found out the problem was my wastegate. i put a clamp on the vacume line to the waste gate and now am boosting at a whoppin 3PSI!! lol all i need i think is a manual boost controller and ill b set.
post Sep 24, 2005 - 12:10 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
good to hear you got it fixed man
post Sep 24, 2005 - 10:11 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
now the only problem is the intercooler piping. the clamps keep comming loose from the boost and the rubber piece that connects the turbo to the 1st part of the intercooler piping keeps coming off and its a pain in the A$$ to get to.
post Sep 25, 2005 - 2:02 AM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
QUOTE(StreetRacing10PSI @ Sep 25, 2005 - 3:11 AM)
[right][snapback]338053[/snapback][/right]
i had that problem 'til i replaced all my clamps with the super dedooper heavy duty plumbing clamps from home depot. biggrin.gif freakin' things are super strong!!! no probs boosting to 9psi now. the ones found on ebay are weak as hell thats why my old ones kept coming loose whenever i boosted.
bboy
post Sep 25, 2005 - 7:10 AM
i recommend some good T-bolt clamps from a reputable source like hightempsilicone.com or turbohoses.com or one of them places.
ive been using those since i started my turbo project, and havent had one loose connection yet! smile.gif
post Sep 26, 2005 - 2:35 AM
BBoYRuGGeD
Joined Jun 4, '04
yah im eventually gunna go with the tbolts myself when i start boosting higher biggrin.gif
bboy
post Sep 26, 2005 - 12:03 PM
its not really a matter of how much boost you run. my cheap clamps let go on me in the middle of the highway, last year. i had to pull over, and try to couple them together right next to a hot downpipe with limited space to work...not fun. get the tbolts as soon as u can. ive had mine for over a year and they never let go.
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: February 21st, 2025 - 2:30 PM
