1MZFE Swap into '95 Celica ST, The "V-Celica" |
Sep 23, 2005 - 1:41 AM |
Enthusiast Joined Jul 31, '05 From toronto Currently Offline Reputation: 0 (0%) |
QUOTE(Dr_Tweak @ Sep 20, 2005 - 10:39 PM) QUOTE(playr158 @ Sep 20, 2005 - 3:52 PM) Is it auto or manual, and do you want to use the GT tranny (cheaper) or the E153 (stronger)? And I assume you want the 1MZFE? (ST 5spd is wat i have) wat ever tranny will hold a supachaga [right][snapback]336453[/snapback][/right] Okay well you're going to want an E153 then. At least you don't need the auto/manual conversion. I'm pretty certain that we can score a decent 1MZFE for around $600, installation will be $900, the tranny with the axles and mounts and other BS will probably be close to another $1000, add another $1000 for the odds and ends... $3500... dang, that's a pretty good price! It's because the 1MZ is easier to get and there's no intercooler stuff to deal with. The tricky part of it will be... a. finding a 5-speed 1MZ or b. making an auto 1MZ ECU happy with no auto tranny attached to it (doable) [right][snapback]336756[/snapback][/right] there are a lot of 5spd solaras and camry's here in canada i'm assuming its the same down there in the states... best bet would be solaras since most camry owners prefer automatic -------------------- I've learned my lesson... the best mod you can have for your car is a good alarm system
Sep 23, 2005 - 8:34 AM |
wouldnt you guys think that the engine size would be a great dif in weight in the celi. Make it more nose heavy? It would prolly help a good bit for the traction issues, but for handling? Id still love to see it.
Sep 23, 2005 - 11:55 AM |
QUOTE(Digndoug @ Sep 23, 2005 - 8:34 AM) wouldnt you guys think that the engine size would be a great dif in weight in the celi. Make it more nose heavy? It would prolly help a good bit for the traction issues, but for handling? Id still love to see it. [right][snapback]337589[/snapback][/right] the aluminum v6 is about the same weight as the 3sgte. To answer your question, weight would not be a real issue. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 23, 2005 - 12:38 PM |
even if weight is an issue....coilovers help to adjust the suspension properly
Sep 23, 2005 - 1:33 PM |
QUOTE(jgreening @ Sep 23, 2005 - 9:55 AM) QUOTE(Digndoug @ Sep 23, 2005 - 8:34 AM) wouldnt you guys think that the engine size would be a great dif in weight in the celi. Make it more nose heavy? It would prolly help a good bit for the traction issues, but for handling? Id still love to see it. [right][snapback]337589[/snapback][/right] the aluminum v6 is about the same weight as the 3sgte. To answer your question, weight would not be a real issue. [right][snapback]337646[/snapback][/right] I believe it weighs less by about 40lbs. |
Sep 23, 2005 - 1:45 PM |
QUOTE(FallenHero @ Sep 23, 2005 - 1:33 PM) QUOTE(jgreening @ Sep 23, 2005 - 9:55 AM) QUOTE(Digndoug @ Sep 23, 2005 - 8:34 AM) wouldnt you guys think that the engine size would be a great dif in weight in the celi. Make it more nose heavy? It would prolly help a good bit for the traction issues, but for handling? Id still love to see it. [right][snapback]337589[/snapback][/right] the aluminum v6 is about the same weight as the 3sgte. To answer your question, weight would not be a real issue. [right][snapback]337646[/snapback][/right] I believe it weighs less by about 40lbs. [right][snapback]337680[/snapback][/right] Until you get the supercharger on there -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 24, 2005 - 12:14 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(behindthesmile @ Sep 23, 2005 - 6:41 AM) there are a lot of 5spd solaras and camry's here in canada i'm assuming its the same down there in the states... best bet would be solaras since most camry owners prefer automatic [right][snapback]337554[/snapback][/right] But are they V6 5-speeds? -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 24, 2005 - 4:51 AM |
QUOTE(Dr_Tweak @ Sep 24, 2005 - 12:14 AM) QUOTE(behindthesmile @ Sep 23, 2005 - 6:41 AM) there are a lot of 5spd solaras and camry's here in canada i'm assuming its the same down there in the states... best bet would be solaras since most camry owners prefer automatic [right][snapback]337554[/snapback][/right] But are they V6 5-speeds? [right][snapback]337848[/snapback][/right] yeah as far as i know they are 5speeds with the 1mzfe engine -------------------- I've learned my lesson... the best mod you can have for your car is a good alarm system
Sep 24, 2005 - 5:52 AM |
QUOTE(behindthesmile @ Sep 24, 2005 - 9:51 AM) QUOTE(Dr_Tweak @ Sep 24, 2005 - 12:14 AM) QUOTE(behindthesmile @ Sep 23, 2005 - 6:41 AM) there are a lot of 5spd solaras and camry's here in canada i'm assuming its the same down there in the states... best bet would be solaras since most camry owners prefer automatic [right][snapback]337554[/snapback][/right] But are they V6 5-speeds? [right][snapback]337848[/snapback][/right] yeah as far as i know they are 5speeds with the 1mzfe engine [right][snapback]337877[/snapback][/right] Because the 5SFE with 5-speed is very common, it's the V6 5-speed that's hard to find. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 24, 2005 - 7:20 PM |
Found one on the first page of listings on car-part.com -- 1998 Camry V6 transmission with 89,000 miles for $1000. Admittedly, it was the only manual V6 I saw on that page, but that was one of 46 pages of 1998 Camrys. I didn't bother widening my search beyond that one year.
They are uncommon compared to the autos, certainly, but there were so bloody many Camry/Solaras put out... |
Oct 4, 2005 - 4:17 PM |
Its very possible, u just need the motor mounts of off the V-6 camry and put it into to your celica. Everything should bolt right up.
Lo-Fi Version | Time is now: December 2nd, 2024 - 12:49 AM |
