ct-26 turbo, lines |
Sep 18, 2005 - 4:57 PM |
Enthusiast Joined Feb 15, '05 From Frederick, Maryland Currently Offline Reputation: 8 (75%) |
there are two lines that come off of the ct-26 turbo's (twin entry) wastegate which one goes where???????
Sep 18, 2005 - 5:28 PM |
in a 3s, the one that points twoard the front of the car goes to the turbo housing, the other goes to the turbo VSV, at the rear of the engine (the purple canister).
for a 5sfte, or with a boost controller, the one that points to the rear gets capped. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 18, 2005 - 8:35 PM |
thanks and another question is can i just put a black off plate on the water coolant lines? and theres an outlet on the compressor turbo housing i understand that the one on thetip is connected to the wastegate but theres another one is that the oil drain?
Sep 19, 2005 - 5:47 AM |
QUOTE(yungazzdriver @ Sep 18, 2005 - 9:35 PM) thanks and another question is can i just put a black off plate on the water coolant lines? and theres an outlet on the compressor turbo housing i understand that the one on thetip is connected to the wastegate but theres another one is that the oil drain? [right][snapback]335798[/snapback][/right] no, on the turbo, there are 2 spots to attach hardlines too. one is the oil feed/return the other is for the water lines. DO NOT block them off, thats what cools your turbo. the hose that goes from your wastegate to the turbo attaches to the nipple that comes out of the compressor housing. -------------------- Former Team 5SFTE pro member ;)
Sep 19, 2005 - 7:01 AM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Are you putting a CT-26 on your ST? What manifold are you using?
Sep 19, 2005 - 7:08 AM |
im going custom its a b16 turbo manifold and cut both flanges and welded new ones but i still needed to know where it gets feeds from and were it lets it out (oil inlet outlet) and how do i attach coolant lines to those(water)
This post has been edited by yungazzdriver: Sep 19, 2005 - 7:09 AM |
Sep 19, 2005 - 1:03 PM |
your using a ct-26 on the 7a?
Sep 19, 2005 - 5:45 PM |
yupppppz
Sep 19, 2005 - 7:25 PM |
youve got a long road ahead of you.
you REALLY need to start searching the forums, there are some very good writeups and tips about the 7afte all over the board. youll get the oil feed from your stock oil pressure switch location, and have to drill your oil pan for a return line. for the coolant lines, you'll have to talk to the 7afte guys, im a 5sfte specialist -------------------- Former Team 5SFTE pro member ;)
Sep 20, 2005 - 6:40 AM |
yes i know that but i need to know where it is on the turbo
Sep 20, 2005 - 8:18 AM |
if you look at the turbo, there are 2 "ports" on it. one with 2 holes, (oil feed and return) and one with one larger one, thats coolant
Sep 20, 2005 - 10:38 AM |
Enthusiast Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
you should talk to nik bout the 7afte. he's the pro. and doggy have a pretty awesome set up too. they know their shizzo.
Sep 20, 2005 - 11:18 AM |
hey yo thanks peeplez i now understand!!!
Lo-Fi Version | Time is now: January 12th, 2025 - 12:47 AM |
