> 3sgte swap pics
post Sep 18, 2005 - 8:16 PM
well i was in baltimore this weekend to assist rob in his swap since a guy screwed him over big time we spent like 4.5 hours working on a lot of stuff.
we began with trying to find bolts, mounts, cables, and sensors from a pile of stuff and a sideways clip.
then we pushed the car over to a lift and started to work on big pieces...
bolts where the wrong sizes in the wrong places and some things were not even hooked up. so we attempted to reattach the steering, under body chassis brace, cross member, and numerous other pieces...
here are a few sneak peaks i got with my fone
post Sep 18, 2005 - 8:31 PM
why did they disconnect the steering? seems like they really didnt know what they were doing
post Sep 18, 2005 - 9:14 PM
yea the guy was a total idiot.....from what i saw
post Sep 18, 2005 - 9:53 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
damn that disc brake is TINY, is that a st? i didn't think my gts were that small
trdevelopment
Joined Jul 27, '04
From phoenix az
yeh thats why im leaning towards doing the swap myself when i get my clip.
post Sep 18, 2005 - 10:29 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Looks like fun, The steering rack connects differently on the ST than a GT.
Its connected to the crossmember. I agree they shouldnt have touched it.
good luck fellas
DEF
I will return one day.
post Sep 18, 2005 - 10:39 PM
Rjb23
Joined Feb 8, '04
From KY
Yea U don't know why the did that, you can drop the subframe without touching the steering.
As long as I can get an ECU, I should be ok. I have peoples numbers like DG and you Jeff, if I run into any trouble.
We re-attached the steering twice cus we forgot to center the wheel lol. Thanks for the help player.
post Sep 19, 2005 - 8:44 AM
post Sep 19, 2005 - 7:33 PM
Rjb23
Joined Feb 8, '04
From KY
I found out today that when he took the hubs off the clip he just cut all the bolts.
Luckily DG has a set of hubs and axles he is gonna sell me.
post Sep 19, 2005 - 7:41 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Why are you buying hubs ?
post Sep 19, 2005 - 8:04 PM
Rjb23
Joined Feb 8, '04
From KY
DG, he has the hubs and axles.
post Sep 19, 2005 - 8:06 PM
but you dont have to change the hubs out for the swap. what tranny are you using
post Sep 19, 2005 - 8:07 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Yes I know. My question is WHY are you buying hubs ?
I'm curious
post Sep 19, 2005 - 8:43 PM
Rjb23
Joined Feb 8, '04
From KY
I'm using the E153 tranny not the the s54.
Someone told me I would need the hubs off the st185. Will the 185 axles fit in the ST hubs?
post Sep 19, 2005 - 8:50 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
The knuckles from my 185 very similar to my ST's.
You should try to bolt up the 185 axle to your ST knuckle see if it fits.
I'm not 100% on the E153 info. but its a good idea to check.
DEF
post Sep 19, 2005 - 8:57 PM
Rjb23
Joined Feb 8, '04
From KY
Hmmmm can anyone say for sure?
post Sep 19, 2005 - 10:11 PM
most people make hybrid axels. take off the ends of your axel and stick them on the mr2 axels
ive yet to hear of anyone replacing the whole hub
post Sep 20, 2005 - 8:22 PM
Rjb23
Joined Feb 8, '04
From KY
Yea thats what I plan on doing, I'm talking about the part that holds the brake calipers on and the rotor.
Lo-Fi Version Time is now: January 11th, 2025 - 9:50 PM
