idle question |
idle question |
Sep 21, 2005 - 1:40 AM |
what do you mean by idle fixed? Is it too low, too high?
Shakes? when the idle is rough, that ussually means you need to do a tune up. If that doesnt help, it can be another problem. To answer you question, you can take your car to a toyota dealership for almost anything. but it will cost alot. |
Oct 4, 2005 - 4:18 PM |
If its shaking like crazy its your timing.
Oct 6, 2005 - 2:14 AM |
Enthusiast Joined May 18, '05 Currently Offline Reputation: 0 (0%) |
QUOTE(soulshadow @ Oct 4, 2005 - 2:18 PM) If its shaking like crazy its your timing. [right][snapback]341138[/snapback][/right] true if you take your timing light and set it to 14 degrees the timing mark should be on zero.... a steady zero... now i had a problem with that, i found out that i had a worn timing belt because when i took the timing light and pointing it to the mark i notice it jumping from 0 degrees to 5 degrees... basically it just wasn't a steady reading. Dont listen to anyone if they say it does that because of a misfire. So then i replaced the timing belt and now its hitting directly zero and the idle got a little better. Now Im not the greatest mechanic, but i know a little. Just try that out. |
Lo-Fi Version | Time is now: December 2nd, 2024 - 7:31 AM |
