> How much Psi??, on a 4age
post Sep 21, 2005 - 1:41 AM
94silverst
Joined Feb 20, '04
From Washington
Just wondering what you guys think a turbo 4age (4agte?) would hold. I'm in the process of the 4age swap and am going to turbo it next summer. Interested in opinions!! Thanks!!! smile.gif
post Sep 21, 2005 - 2:00 AM
On a stock silvertop I wouldn't run more than 5-7 lbs. What do you plan to do as far as engine management for your turbo setup?
post Sep 21, 2005 - 9:18 AM
nik
Joined Sep 30, '02
QUOTE(Coomer @ Sep 21, 2005 - 12:00 AM)
[right][snapback]336859[/snapback][/right]
ditto i wouldnt go over 6 psi on t3 turbo you can swap the 4agze rods in there stronger but for more info go to club4ag they have 2 stickies on the silvertop over there. i would go with a smaller turbo to get some bottom end back
post Sep 21, 2005 - 10:03 AM
nik
Joined Sep 30, '02
QUOTE(nik @ Sep 21, 2005 - 7:18 AM)
[right][snapback]336903[/snapback][/right]
HERE
http://forums.club4ag.com/topic.asp?TOPIC_ID=118358
he is selling intakes for teh 20v for turbo applications
post Sep 21, 2005 - 10:51 AM
The silvertop's rods are just as strong as the AE101 4A-GZE rods...it's the high compression that prevents high boost levels.
post Sep 21, 2005 - 11:40 AM
nik
Joined Sep 30, '02
QUOTE(Coomer @ Sep 21, 2005 - 8:51 AM)
[right][snapback]336923[/snapback][/right]
I remeber reading that over there (club4ag) isnt the compression on a Silver top 10.5:1
i found a few places that have 5 valve pistons in lower comp like 9.0:1 and lower
but there spendy like $400+ not including rings and you need a manifold very hard to find one probably just have to have one custom made
post Sep 21, 2005 - 12:47 PM
Yep, it's 10.5:1 on the silvertop. Many people use the 4A-GZE pistons and either have them flycut(I think that's the word), keeping the motor non-interference, or just leave them as is, turning the motor into an interference motor should the timing belt break.
For a manifold, the ports are the same as the 16V 4A-GE...the two outside bolts are just in a different place I believe. So a B-series manifold like yours would work if it were welded to a 20V flange.
post Sep 21, 2005 - 1:06 PM
nik
Joined Sep 30, '02
i looked back in all my fav links and yep you have to get a set of 4agze pistons and take or send them somewhere to have the 5th valve slot cut
post Sep 21, 2005 - 1:11 PM
nik
Joined Sep 30, '02
here i hope this link works
http://cgi.ebay.com/ebaymotors/4AG-4AGE-20...002173104QQrdZ1
Custom Forged Arias pistons for the
Toyota 4AGE 20V motor!!!
Where you planning on turning up the power on your 20V???
Boost, nitrous or normally aspirated???? Well you gotta have these!!!
Up for grabs is a brand new in box set of Arias low compression pistons for the Toyota 4AGE 20V motors. We do not cheat and separate items so they come complete with pistons, rings and wrist pins.
Please notice the 5 valve pockets for increased piston to valve clearence!!
They come in 9.0 compression in 81.5mm bore!!!
We also have multi layer steel head gaskets from 1mm to 3mm!!!
Buy it now will recieve free shipping in the U.S. and a free Paradise Racing T Shirt!!!
These are custom pistons that normally sell for $699.00!!!
If you have any questions, please feel free to visit www.paradiseracing.com or call us @ 240-508-1449 Check out our other toyota related auctions.
Thanks & Good Luck!!!
Powered by eBay Turbo Lister
Select a picture
This post has been edited by nik: Sep 21, 2005 - 1:14 PM
post Sep 22, 2005 - 1:11 AM
94silverst
Joined Feb 20, '04
From Washington
Thanks guys!! this info helps alot!!
post Oct 4, 2005 - 4:32 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I was thinking of going full open throttles. Its something that you don't really see everyday in a car. Then again, you will rarely see a JDM engine in a 6G celica.
Lo-Fi Version Time is now: December 4th, 2024 - 12:10 PM
