> Next Modification, what should i do next?
post Sep 21, 2005 - 12:14 PM
94ST2
Joined Feb 7, '05
From Fresno, CA
Alright I have CAI, and 2.25 catback exhaust already. My question is now what should I do I cant decide whether to continue with performance or start to go into styling.
post Sep 21, 2005 - 3:51 PM
celicaST
Joined Jun 23, '05
well from your profile i assume your still with the stock steel wheels for the st? if so, save up and buy a set next. hub caps are just ugly, plus larger wheels will make a nice difference in handling. i suggest 16's.
This post has been edited by celicaST: Sep 21, 2005 - 3:53 PM
post Sep 22, 2005 - 2:37 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
Yeah thats what I was thinking about doing next. I took the hubcaps off and painted everything flatblack it looks ok for now but i definately need some rims.
post Sep 22, 2005 - 3:27 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
ACTUALLY if you want my opinion...since you already have a cai & exhaust why not get the header to further remove restriction of airflow? otherwise ain't sh*t goin on really!
then maybe after that you would maybe consider brakes/suspension/drivetrain remember you can't see your rims when you're driving but you can feel the clutch/throw of the short shifter/suspension/brakes as you drive! so what if a few GUYS look @ your car? !!!have fun driving it!!!. cuz a girl isn't gonna look @ your car and wanna screw your brains out right off the bat! remember that.
This post has been edited by purplegt4: Sep 22, 2005 - 3:30 AM
post Sep 22, 2005 - 12:14 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(purplegt4 @ Sep 22, 2005 - 4:27 AM)
[right][snapback]337236[/snapback][/right]
I like your posts. The only thing I'd have to say different is that maybe some stock 5 spoke alloys off a 6th or 7th gen might be a good idea. Or whatever rim really. The steel wheels are skinny, heavy, and really look bad. I'm all about performance, and I think this would be the next step. That, and getting rid of your neons. Next, lower the car a little with springs, and put some bigger sway bars on. The Celica is not a fast car, that's a fact. It can be helped by intake, exhaust, headers, ECU, exc. But it won't be to fast unless you swap in a 3s. It can however be good at handling. I personally have kept my upgrades even between engine and suspension, and I'm reasonably happy with it. But in all seriousness, get rid of the neons. Just my opinion.
Live Free, Be Happy
post Sep 22, 2005 - 11:45 PM
94ST2
Joined Feb 7, '05
From Fresno, CA
LoL I know the neons are super rice but for some reason I just like them. Well I have decided to wait a while to get rims. Im gonna do a window tint and then probably get a header.
post Sep 23, 2005 - 12:10 AM
celicaST
Joined Jun 23, '05
remember that a free flowing exhaust isnt necessarily going to net hp gains. an engine's valve overlap is designed to take advantage of the phenomenon known as engine scavenging. by decreasing backpressure a number of problems may result including a low in low end torque. heres an article i found real quick for ya http://www.flowmastermufflers.com/backpressure.html this is why i am planning on buying my exhaust setup when i install my turbo. what i am trying to tell you is not to waste your money on a damn header, it will look nice, but just start saving for a turbo or a swap if you want performance. and kill the neons smile.gif.
This post has been edited by celicaST: Sep 23, 2005 - 12:15 AM
post Sep 23, 2005 - 12:13 AM
celicaST
Joined Jun 23, '05
double post
post Sep 23, 2005 - 12:44 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
Im not going the turbo route or a swap maybey a small nitrous set up in a year or so but mainly I just want basic perfomance out of this car and then in another year I plan to get a project car and just drive this one around while I fix up the project.
post Sep 25, 2005 - 9:48 PM
purplegt4
Joined Feb 7, '03
ok ok after reading your posts it hit me...that's why i dont have an exhaust/header yet! hahaha yea dont waste your money on performance for the stock engine... redface.gif
post Sep 27, 2005 - 7:21 PM
95ST
Joined Jan 1, '03
From CT
another mod that I dont see mentioned often here that I have done and really enjoyed is a lightweight flywheel/good clutch.
post Sep 28, 2005 - 1:41 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
I have looked into that and I am probably going to do that after getting a header.
post Sep 28, 2005 - 10:10 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(95ST @ Sep 27, 2005 - 8:21 PM)
[right][snapback]338896[/snapback][/right]
I've done this, and all I've seen is quicker revving when in neutral. If you have to replace the clutch, and flywheel, then go for it, but don't take out good parts and these in.
Live Free, Be Happy
Lo-Fi Version Time is now: January 9th, 2025 - 10:58 PM
