Sep 22, 2005 - 2:13 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
I'm hooking up the wires from my AT200 cluster to the corresponding wires on the new ST205 cluster. Things are a bit different and more than half the wires are either ground wires that lead to screws behind the cluster or are just not used... I have some questions... Can I just tape off or cover the wires that are supposed to be grounded(this way it's like if they weren't in use) or do I HAVE TO ground them to some chassis piece of metal? I'm not going to ground them using the screws on the cluster because they lead to other things or one cluster has more ground wires than the other... Also, can I ground all these wires to on spot? Like if I find a screw somwhere near the metal stuff behind the dash, can I connect all the ground wires to one ground? Thanks a lot guys. An answer a.s.a.p. to all these questions would be unimaginabley greatly appreciated. Thanks in advance.
This post has been edited by JoKeRkId613: Sep 22, 2005 - 5:06 PM -------------------- ![]() |
JoKeRkId613 ST205 CLUSTER Sep 22, 2005 - 2:13 PM
JoKeRkId613 Please help. I just don't want to cause a shor... Sep 22, 2005 - 5:07 PM
JoKeRkId613 I have a topic about an ST205 cluster. I've se... Sep 22, 2005 - 10:11 PM
Batman722 so, you are saying the 205 cluster has wires that ... Sep 22, 2005 - 11:03 PM
presure2 joker, i merged your multiple posts about the same... Sep 23, 2005 - 7:33 AM
JoKeRkId613 ^I like the "JDM" style. The boost gauge... Sep 23, 2005 - 1:47 PM![]() ![]() |
| Lo-Fi Version | Time is now: December 14th, 2025 - 12:17 PM |
