Timing on JDM 3s |
Timing on JDM 3s |
Sep 24, 2005 - 4:49 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Hey guys I'm replacing the timing belt, and according to the manual when the hole in the crank pully is at 0 the marks on the cam shaft pulleys should be at the 12 o clock position. But the book I have is for a 91 USDM alltrac. Well at 0 the cam pulleys are at about 10 o'clock and if I turn it another revolution, the pulleys are at about 3 or 4 o clock.
Can my timing be this far off? Should I just reset them? |
Sep 24, 2005 - 5:37 PM |
Ok its wierd I pulled the valve cover off to check the cam alignment marks and they were right on, and I also check for TDC in #1 cylinder and it was TDC so I guess its ok. Just the crank pulley mark is not lining up.
Sep 24, 2005 - 6:25 PM |
i never did my own belt so i dont have any tips to offer, but i can tell you there is no difference between the jdm and usdm versions, so try anything your bgb recomends.
Sep 24, 2005 - 7:35 PM |
Well it looks like its in time when I go by the key in the crank, and the marks on the cam sprockets. So I think I'm good.
On a side note when I took the valve cover off everything looked really good for an engine that has been sitting for a while. Also guys who have 3's who do you get your oil filter off, it looks like its gonna be hard. |
Sep 24, 2005 - 7:45 PM |
you have to take off the altinaor....or just remove that air duck cover. i just swaped in my 5sfe altinator without that dumb air ducking to make more room there.
Sep 25, 2005 - 3:45 PM |
I figured it out, everything has to be 12 o'clock. Go by the key in the crank not the mark on the pulley.
For anyone doing the timing belt on these you better have a vise to compress the timing belt tensioner or it is impossible to get the the it back on. |
Sep 25, 2005 - 5:33 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
QUOTE(Rjb23 @ Sep 25, 2005 - 3:45 PM) For anyone doing the timing belt on these you better have a vise to compress the timing belt tensioner or it is impossible to get the the it back on. [right][snapback]338185[/snapback][/right] As long as your tensioner doesnt break -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Sep 25, 2005 - 9:28 PM |
Did yours break?
If the tensioner broke you probably needed a new one anyway. Well the engine is in the car now, I'll have pics later this week. I'm still waiting on the ECU and the passenger side mount. Wiring is 99% done I have 5 or 6 wires that either have the exact same colors on the other side of the harness or don't match up to a wire. I'll have pics of those if someone can help out with em. |
Sep 25, 2005 - 9:36 PM |
Yeah, mine broke. Any idea on how much one of them will cost?
Sep 26, 2005 - 5:51 PM |
Prolly like $60 at a toyota dealership.
Lo-Fi Version | Time is now: January 10th, 2025 - 10:22 AM |
