> Diode Isolation, On Keyless Entry/Alarm
post Oct 2, 2005 - 2:02 PM
Cutrara
Joined May 6, '05
From PA
I'm installing my old Bulldog Keyless entry on my sister's 94 ST, and I asked went to RadioShack and told them I needed 2 12V 1AMP Diodes (that's what I used on my car, and re-used them when I bought an alarm) they didn't have 1AMP in 12V, so I got the biggest they had, 21mA which is a lot smaller than 1AMP. I really don't feel like going out and hunting down 1AMP diodes.
My guess is it will render one of those "Don't lock your keys in your car" features useless. If I absolutely have to, I'll get 1AMPs but it's not a big deal to me, lol.
What will happen if I use the smaller ones?
post Oct 2, 2005 - 3:29 PM
Snarfer
Joined Dec 2, '03
From Virginia
i'm confused what you are trying to do... if you use a 21mA diode where a 1A is called for you will most likly burn the diode up. if you are just trying to isolate a circuit, meaning current will only flow in one direction then you just need a PIV rating of higher then 12V and a current rating higher then what will flow through that wire. just go try a 1n4001 (PIV: 50V, Imax: 1A) they cost about 10 cents.
post Oct 2, 2005 - 4:33 PM
What are you trying to diode-isolate?
post Oct 2, 2005 - 10:48 PM
snadman
From Minnesota, USA
The door triggers aren't separate so there is nothing to diode-isolate on the Celica. A lot of GMs the door triggers are separate so this is necessary but in our case it isn't.
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Oct 3, 2005 - 7:04 AM
Cutrara
Joined May 6, '05
From PA
No, all of you misunderstood me. I know diodes only let power feed one way and I was under the impression that the unlock wires going from the alarm brain to the door control module had to be diode-isolated. It says this in all of my alarm instructions and it also says it in the alarm install guide. I used 1AMP on my car, and used 21mA on my sister's 6GC, and it worked fine, no problems after a thorough test.
Lo-Fi Version Time is now: November 27th, 2024 - 3:00 AM
