Oct 3, 2005 - 9:18 PM
Enthusiast ![]() ![]() Joined Sep 23, '04 From fresno Currently Offline Reputation: 0 (0%) |
alright ...i have done alot of search on the forums but they never really talk about ..what type of axles are being used with the mr2 turbo transmission ??.. plus the car has been sitting for 2 month now without any clue on what type of axles are being used !!!!!! here a little infor on the project car its a 94 celica st 5sp with a 3sgte 2ndgen from a mr2 turbo...and now all i need is just the axles.to get the car running.....
P.S dont get flame |
Oct 3, 2005 - 9:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
http://www.6gc.net/forums/index.php?showtopic=22856&hl=axle
ok from what i know 91 camry outers and the inners have to match with the year of the tranny. and also i think celica3sgte mentioned that a specific (i think) year alltrac axle as the outer would work. bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Oct 3, 2005 - 9:46 PM
thanks..i'll try to look for more infor as i read
Oct 3, 2005 - 9:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
You can use 90-93 all-trac outers or v6 camry outers. And you need the inner axles, stub shaft and bracket that match up to the mr2 tranny you have.
Like I have a 91 mr2 turbo tranny without lsd and abs. I need the mr2 stub shaft, bracket, carrier bearing, and passenger side inner axle, then you need the driverside inner axle as well. You unbolt the inner axle from the outer and bolt the inner to the outer of the alltrac axles. |
Oct 4, 2005 - 7:56 PM
also another question about transmission.??? isn't the 91-94 mr2 5sfe non-turbo and the celica gt 5sfe has the same transmission ??? since its alot harder to find the celica gt 5sfe transmission..could i just used the mr2 5sfe tranny as welled instead of using a celica gt transmission, since the celica gt and the mr2 5sfe has the same engine and tranny...
This post has been edited by st_celica_killer: Oct 4, 2005 - 7:57 PM |
Oct 4, 2005 - 8:37 PM
Its the same tranny but the shift linkage is still reversed I think, the same as the turbo tranny, but I'm not sure on this.
Both trannies you need to do some custom stuff to use, the e153 you have to make the axles and a either a st205 rear mount or a custom mount, switch the shift linkages, and if you have a 93 or older you have to switch the speedo assy. to an electric one instead of the mechanical one that is in a 93 or older. The s54 you have to piece together a clutch kit and its not as strong. |
Oct 4, 2005 - 9:06 PM
since its like that ...couldnt i just got buy a 5sfe tranny and take the shiftlinkage off of it and bolt it on to the mr2 turbo tranny....??? or is there some other way converting the mr2 turbo tranny to a FF.?. i did came across this web sit .look like it belong to 6gc member http://www.geocities.com/zegoat2000/e1531.html
but is there any easier way converting the mr2 turbo tranny to a FF? |
Oct 4, 2005 - 9:43 PM
No you have to have the alltrac tranny shift linkage to do the mr2 turbo tranny. Or if you can find a solara tranny you can use that without converting the shift linkage because the engine is in the front.
Your not converting the tranny to FF your just puttiing the linkage on the other side of the tranny so that the linkage is on the side of the tranny closest to the firewall. |
Oct 4, 2005 - 10:16 PM
QUOTE(Rjb23 @ Oct 5, 2005 - 2:43 AM) No you have to have the alltrac tranny shift linkage to do the mr2 turbo tranny. Or if you can find a solara tranny you can use that without converting the shift linkage because the engine is in the front. Your not converting the tranny to FF your just puttiing the linkage on the other side of the tranny so that the linkage is on the side of the tranny closest to the firewall. [right][snapback]341253[/snapback][/right] how about if i dont want to used the solara tranny..is there any other way shift linkage that fit on to the mr2 turbo tranny...??? by the way i really appreciate your kind help... what about this tranny i found on ebay...?? http://cgi.ebay.com/ebaymotors/88-96-Toyot...003676910QQrdZ1 This post has been edited by st_celica_killer: Oct 4, 2005 - 10:18 PM |
Oct 4, 2005 - 10:26 PM
QUOTE(st_celica_killer @ Oct 5, 2005 - 3:16 AM) QUOTE(Rjb23 @ Oct 5, 2005 - 2:43 AM) No you have to have the alltrac tranny shift linkage to do the mr2 turbo tranny. Or if you can find a solara tranny you can use that without converting the shift linkage because the engine is in the front. Your not converting the tranny to FF your just puttiing the linkage on the other side of the tranny so that the linkage is on the side of the tranny closest to the firewall. [right][snapback]341253[/snapback][/right] how about if i dont want to used the solara tranny..is there any other way shift linkage that fit on to the mr2 turbo tranny...??? by the way i really appreciate your kind help... what about this tranny i found on ebay...?? http://cgi.ebay.com/ebaymotors/88-96-Toyot...003676910QQrdZ1 [right][snapback]341272[/snapback][/right] The link is not working. No if you want the e153 tranny there is no other way, you have 2 options. 1. An mr2 turbo e153 tranny and the all trac tranny with shift linkage like it says on steve's site. 2. A solara v6 tranny. If you want the 5sfe tranny save yourself the headache and just get one from a celica or other front mount engine car. |
Oct 4, 2005 - 10:33 PM
alright that clear it up....
Oct 4, 2005 - 10:48 PM
Enthusiast ![]() ![]() ![]() Joined Feb 27, '04 From Illinois Currently Offline Reputation: 1 (100%) |
ok, so I have a 94 mr2t transmission and the axles. So do I only need the v6 camry outter shafts?
Oct 4, 2005 - 11:08 PM
QUOTE(Yota @ Oct 4, 2005 - 10:48 PM) ok, so I have a 94 mr2t transmission and the axles. So do I only need the v6 camry outter shafts? [right][snapback]341293[/snapback][/right] And the shift linkage from a V6 camry or alltrac. I would recommend getting the shift linkage from the same year car as your tranny as I had problems with mine originally because they used the shift linkage from a 92 alltrac but I have a 93 MR2T tranny. I replaced the linkage with that from a 93 alltrac and it worked. The total cost of the new shift linkage parts was about $160 from Toyota. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Oct 4, 2005 - 11:27 PM
ok so anyone happen to know exactly what's required if the solara or camry v6 tranny is used? is it the same procedure as the mr2t tranny way in terms of axles, shift linkage, and mounts???
Oct 4, 2005 - 11:29 PM
QUOTE(BBoYRuGGeD @ Oct 4, 2005 - 11:27 PM) ok so anyone happen to know exactly what's required if the solara or camry v6 tranny is used? is it the same procedure as the mr2t tranny way in terms of axles, shift linkage, and mounts??? bboy [right][snapback]341314[/snapback][/right] No, its not. The shift linkage bolts up - unlike the MR2T. You are still going to need MR2T inner shafts and V6 camry or alltrac outers. This post has been edited by jgreening: Oct 4, 2005 - 11:29 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Oct 5, 2005 - 12:31 AM
QUOTE(jgreening @ Oct 5, 2005 - 4:08 AM) QUOTE(Yota @ Oct 4, 2005 - 10:48 PM) ok, so I have a 94 mr2t transmission and the axles. So do I only need the v6 camry outter shafts? [right][snapback]341293[/snapback][/right] And the shift linkage from a V6 camry or alltrac. I would recommend getting the shift linkage from the same year car as your tranny as I had problems with mine originally because they used the shift linkage from a 92 alltrac but I have a 93 MR2T tranny. I replaced the linkage with that from a 93 alltrac and it worked. The total cost of the new shift linkage parts was about $160 from Toyota. [right][snapback]341302[/snapback][/right] well toyota sell the complete alltrac shiftlinkage????? or is it parts by parts????...if so could i have the part numbers as well... |
Oct 5, 2005 - 12:45 AM
QUOTE(st_celica_killer @ Oct 5, 2005 - 12:31 AM) QUOTE(jgreening @ Oct 5, 2005 - 4:08 AM) QUOTE(Yota @ Oct 4, 2005 - 10:48 PM) ok, so I have a 94 mr2t transmission and the axles. So do I only need the v6 camry outter shafts? [right][snapback]341293[/snapback][/right] And the shift linkage from a V6 camry or alltrac. I would recommend getting the shift linkage from the same year car as your tranny as I had problems with mine originally because they used the shift linkage from a 92 alltrac but I have a 93 MR2T tranny. I replaced the linkage with that from a 93 alltrac and it worked. The total cost of the new shift linkage parts was about $160 from Toyota. [right][snapback]341302[/snapback][/right] well toyota sell the complete alltrac shiftlinkage????? or is it parts by parts????...if so could i have the part numbers as well... [right][snapback]341332[/snapback][/right] No, they don't sell it complete. There is something like 13 small parts that need to be assembled. I suggest that you GO TO a toyota dealer (do not call for this one) and tell the guy what you need. Essentially, you need the actuator and all the parts that go on to the actuator. The main actuator shaft attaches to the firewall side of the tranny by four bolts and that is the part that hooks up to the shift cables. On the other side of the mounting plate, the actuator extends into the tranny and the other parts fit onto the shaft. A few of them are similar to tumblers in a lock mechanism and serve to select the gears. (Warning, the terms I am using here like "shift linkage" "actuator" etc. may not be all that precise but if you explain what parts you want to a competent toyota parts guy, you should be ok). -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Oct 5, 2005 - 1:13 AM
ah wow great info. so the shift linkage (GT shift linkage correct?) bolts right up to the camry v6 trans right? and the axles still gutta be assembled just as if ure using the mr2t tranny. what about the mounts? st205 mounts (the 3 tranny mounts) are a direct bolt to the camry v6 trans? tho i imagine so since its still an e153 tranny right?
Oct 5, 2005 - 1:30 AM
QUOTE(BBoYRuGGeD @ Oct 5, 2005 - 1:13 AM) ah wow great info. so the shift linkage (GT shift linkage correct?) bolts right up to the camry v6 trans right? and the axles still gutta be assembled just as if ure using the mr2t tranny. what about the mounts? st205 mounts (the 3 tranny mounts) are a direct bolt to the camry v6 trans? tho i imagine so since its still an e153 tranny right? bboy [right][snapback]341344[/snapback][/right] Yes, although there is some debate if using ST205 cables might be better. I have the GT cables on mine and they are working but I have had intermittent shifting problems that are currently resolved. My current theory about my shifting woes is worn motor mounts. As for the motor mounts, I think you need a ST205 rear mount and either GT or ST205 mounts in the other places if you are using the E153. I am not sure about this though. I would do a search on the word "mount" in the forced induction section and look for posts by a guy named ESMS or something like that. He is from Australia and did the MR2T tranny conversion himself and has some good info on mounts. The V6 Camry MT is the same fitment and operation as the MR2T tranny. The only difference is gearing. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Oct 5, 2005 - 1:36 AM
ah aright so then im pretty sure that st205 mounts are needed, actually prolly smarter to use than any other mounts. since thats what supersprint is using on his mr2t tranny. personally im also gunna go with the e153 conversion when next year rolls around and i think ill try the solara or the camry v6 tranny since theyre already front wheel drive trannies. thnx alot jgreening, ur an invaluable source of info!
| Lo-Fi Version | Time is now: September 1st, 2026 - 11:12 PM |
