2 Pages V  < 1 2
> mr2 turbo transmission axles, make this clear for once...
post Oct 5, 2005 - 2:00 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(BBoYRuGGeD @ Oct 5, 2005 - 1:36 AM)
ah aright so then im pretty sure that st205 mounts are needed, actually prolly smarter to use than any other mounts.  since thats what supersprint is using on his mr2t tranny.  personally im also gunna go with the e153 conversion when next year rolls around and i think ill try the solara or the camry v6 tranny since theyre already front wheel drive trannies.  thnx alot jgreening, ur an invaluable source of info!  biggrin.gif
bboy
[right][snapback]341354[/snapback][/right]
You're welcome and good luck.
post Oct 5, 2005 - 10:34 PM
Rjb23
Joined Feb 8, '04
From KY
You can use the st205 rear mount, and driverside mount, or you can use the st185 driverside insulator with the mr2 tranny mount, and use the GT bracket and weld a peice of metal to the bottom of the rear insulator that moves it over like an inch and a half.
This is what I plan on doing I have the alltrac insulator with the mr2 tranny bracket, and going custom rear mount. It takes 8 weeks to get the st205 mounts and I can get a custom rear mount from autolab for less than a $100.
post Oct 6, 2005 - 6:44 AM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
QUOTE(Rjb23 @ Oct 6, 2005 - 3:34 AM)
[right][snapback]341600[/snapback][/right]
ah ok so st205 rear and drivers... so the passengers and front GT mounts work with these and need no modification correct?
bboy
post Oct 6, 2005 - 7:58 AM
ems3s
Joined Jun 17, '05
From Melbourne, Australia
You are correct.
St205 left insulator and bracket. (Bracket is no longer available from toyota)
St205 rear bracket and insulator. Only way its going to work w/o going custom
Gt front and right side insulators+brackets. The fronts are actually indentical on both models but have different part numbers.
You can use your gt shifter cables but you'll need some thicker u clips to hold them into place. I'll post some pics of mine when I can be bothered.
When I last checked with toyota Aust. they wanted AU$600 for the 205 cable set.
It only takes a week to get driveline parts in from japan to Australia through toyota because they take priority over cosmetic or body parts, surely it must be the same to the U.S. They'll either tell you up to 3-4 weeks because a. they can be bothered getting them for you or b) just in case the japs are having one of those crazy holiday periods or strikes that go on for weeks at the shipping ports.
While on the topic of Axles I really want to clarify what people have actually used. I've tried using several setups but only one so far has worked. I would like everyone thats done the conversion to state what they've used.
Nothing is more time wasting or annoying than people giving rubbish suggestion or advice because they heard a friend may or may have not used this or that succesfully. Or just going by rumours.
It really needs to cleared up and put in a proper How-to.
I've got a '92 mr2 e153 with lsd, I'm using a middle (the w/ the carrier) shaft with a diameter of 31.3mm no circlip (I think all years are same), 185 outers and 92+ (Lsd) inner stub. I'm having concerns with the way the cvs are stretched atm and will try using a longer in the future.
(Because I only have experience with models available to Aust. and jap imports the following only refers to jdm mr2 e153s)
From all the time spent looking at the toyota Australia's parts finder program, the left inner stub changed from jan 92. They only have one part n# listed for later models there is no reference to lsd or non-lsd. Models produced dec 91 or earlier have the same part no as all camry v6 manuals boxes.
The early model inner left stub is the one with the circlip roughly 7mm from the end. This one is available in abundance in Aust. so most ignorant wreckers think there is only one type.
The Late model is the one with the circlip roughly 20mm from the end.
If anyone knows anymore or any better than this please let us all know so We can put an end to these axle questions
post Oct 6, 2005 - 9:07 AM
scothaniel
Joined May 1, '03
From Michigan
I'm using the GT Passenger side mount on my swap - doesn't seem to be a problem yet. Custom bracket for the rear.
The ST shifter cables are working as well.
I may have a set of new ST185 outers for sell soon - they fit fine for the stock hubs, but are an inch too short for the ST205 superstruts / hubs.
Scott
West Michigan
post Oct 6, 2005 - 9:03 PM
Rjb23
Joined Feb 8, '04
From KY
This is what I have on at the moment, I'll post later on how well it is working.
I have a e153 non lsd tranny, with 91 carrier shaft also with no circlip, 91 driverside innershaft with st185 outers on both sides.
For mounts I have the gt front and passenger side, the st185 or mr2 driverside insulator, mr2 tranny bracket, the mr2 rear bracket, same as the gt, and custom rear insulator.
I also have the st shifter cables they seem to work just fine, no problems with my hand hitting the dash or anything but then again I have a short shifter, the st185 are to short.
2 Pages V  < 1 2
Lo-Fi Version Time is now: September 15th, 2026 - 9:58 AM
