Safc 2, how it works? |
Oct 5, 2005 - 12:21 AM |
I know the safc adjusts the fuel curve by tricking the ecu. But how does it repond to boost?
If you have a boost controler, and you adjust it to zero boost will the safc still be dumping loads of fuel when you dont need it? Likewise if you have it adjusted to have low boost and you adjust your boost controller to a higher setting will the engine lean out? what i am basically asking, is does the safc know what psi of boost there is and correct the fuel mixture accordingly? |
Oct 5, 2005 - 6:03 AM |
the SAFCII does not have anything to do with boost. for the 5sfe it basicly works by tricking the map sensor signal.
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: December 3rd, 2024 - 11:55 PM |
