> fuel cuts off at 5PSI???
post Oct 5, 2005 - 8:37 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
ok so i made a new boost controller that works better and i got it to 6psi for the 1st time but some times around 4-5PSI it makes a funny thrthrthrthr sound and the car loses power. iam thinking its some how related to the map sensor because i dont think its reading boost and the fuel gets cut off. i even set my safc-2 to 0% correction. any ideas????
post Oct 5, 2005 - 10:33 PM
nik
Joined Sep 30, '02
QUOTE(StreetRacing10PSI @ Oct 5, 2005 - 6:37 PM)
[right][snapback]341568[/snapback][/right]
did you adjust your timing
post Oct 6, 2005 - 1:51 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
QUOTE(nik @ Oct 5, 2005 - 11:33 PM)
[right][snapback]341599[/snapback][/right]
no, i herd u only have to adjust timing at higher PSI like 10 plusand now my throttle response is messed up, i floor it and nothing haoppens but i only think that the wire from my ECU to the safc2 is loose cuz its the ONLY 1 i didnt sodder togeather
post Oct 6, 2005 - 3:21 PM
nik
Joined Sep 30, '02
I retarded my timing even at 5-6 psi and i would always sodder any connections for the ecu other than that how is everything?
post Oct 6, 2005 - 3:55 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
found out the wires were fine. from under the hood if i rev it the little rubber piece under the throttle gets stuck and dnt pop out when the throttle cabel is moved. only thing really conected to it is a vacumme line to the intake.
This post has been edited by StreetRacing10PSI: Oct 6, 2005 - 4:00 PM
Lo-Fi Version Time is now: February 22nd, 2025 - 8:28 AM
