a couple questions |
Oct 7, 2005 - 9:09 AM |
OMG
ok, it depends on the color of the smoke comming out (whiteish, blueish, black). A little is fine but if it is excessive then it could be a problem. There are many vaccum hoses in the engine bay. they are small black tubes that run from the throttle body to sensors and such. Check them all because it sounds like one (or more) is cracked or disconnected. to put is simplily, knocking noises and a lot of smoke = bad -------------------- |
Oct 7, 2005 - 11:20 AM |
How could a vacume hose cause an engine to knock? I don't think that's right. I guess it could mess with the computer. If it is the cause, and you don't get it fixed quick, it'll make a real knock. Anything knocking just gets worse with time. Almost any smoke is bad in my opinion. When I start mine up, there's a little burp of it, but that it. Sounds like your car has some serious issues.
Oct 7, 2005 - 12:55 PM |
I don't understand why you even posted this. You've already made up your mind about what is going on and what your going to fix, and what the problem is. You'll see what actually wrong later on when what you do doesn't fix the problem.
Oct 7, 2005 - 8:07 PM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
dude take your car to a mechanic becuase you clearly dont know what your looking for an last time i let a knock go... i spun a rod bearing... you might not know what that is but the motor came out and it got rebuilt piece by piece with many many new parts.. and your bro in law has no clue what hes talking about theres no way a hose will make your engine knock and like what was said earlier if it knocks it only gets worse from there. take it to a shop.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Oct 7, 2005 - 8:34 PM |
Enthusiast Joined Jan 1, '03 From CT Currently Offline Reputation: 0 (0%) |
QUOTE(mon3y19 @ Oct 7, 2005 - 10:11 AM) QUOTE(Bigmeanbulldog55 @ Oct 7, 2005 - 11:20 AM) How could a vacume hose cause an engine to knock? I don't think that's right. I guess it could mess with the computer. If it is the cause, and you don't get it fixed quick, it'll make a real knock. Anything knocking just gets worse with time. Almost any smoke is bad in my opinion. When I start mine up, there's a little burp of it, but that it. Sounds like your car has some serious issues. [right][snapback]342211[/snapback][/right] my brother in law says that i just need to plug the vacuum hose...that's what's making the noise...the smoke im not too worried...its just the muffler...i think i just need to replace it...it's quite old...otherwise the car runs great though... [right][snapback]342225[/snapback][/right] Im sorry but I think you are being mislead. Smoke is not caused by a bad muffler, esp if it is only when you are starting the car. Generally that is a blueish smoke caused by bad valves. And a knocking sound is pretty vauge, but see if you can locate where it is comming from to help us help you. How loud is it? |
Oct 8, 2005 - 10:08 AM |
Enthusiast Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) |
And I was scared when my car gave me a puff of white smoke when I started it up.!!!
-------------------- <<AKA THA RUSSIAN>>
Oct 8, 2005 - 10:28 AM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Definately just take it to a shop. I'm not sure what color smoke you're really seeing , but it doesnt sound right....it could be any number of things wrong and a shop will know what to do and save you a big headache.
I dont know, I've learned to rely on professionals in the event theres something that needs to be diagnosed properly....altough its rare for me to have any problems in the first place. But do it right, please. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Lo-Fi Version | Time is now: January 9th, 2025 - 9:15 PM |
