> How would you install this?, Goofy expensive Cap (audio)
post Oct 7, 2005 - 3:16 PM
spunky393
Joined Apr 22, '04
From illinois
Just wondering how you would install this into your system.
This post has been edited by spunky393: Oct 7, 2005 - 7:40 PM
post Oct 7, 2005 - 7:16 PM
spunky393
Joined Apr 22, '04
From illinois
maybe everybody needs a better question..umm.....if i was running a 4 awg from the battery, where do i go from there? (one amp)
What are the little plug in's for?
post Oct 7, 2005 - 7:41 PM
spunky393
Joined Apr 22, '04
From illinois
hmm..those two are different...
How would you hook up one or the other
and
do you have to have power and ground to battery? And then does it go power and ground to the amp?
post Oct 7, 2005 - 11:15 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
0g ground first. 2nd power into 0g (or your case 4g from battery), there will be some sparks because of the cap gaining power. Then hook your amp into one of the 3 remaining 3 (+)(4g) connectors left, and then ground you amp into 1 of the 3 (-)(4g) connectors left, and your hooked up. They Cap works as a Distro block, and also combining grounds make for a cleaner grounding system and cleaner sound.
DTE
I am a thief.
do not buy anything from me.
post Oct 7, 2005 - 11:29 PM
Niskyspy
Joined Jan 21, '05
From NY
Dude just get a normal round cap with two ports. I dont understand why u would need so many small gauge ports.
<<AKA THA RUSSIAN>>
post Oct 8, 2005 - 5:44 AM
spunky393
Joined Apr 22, '04
From illinois
i don't know where i got the picture of all the small ports.
I was basically backing my self up with the other pictures, that's the one i'm interested in.
Thanks a lot Clip, i appreciate it
post Oct 8, 2005 - 10:00 AM
Niskyspy
Joined Jan 21, '05
From NY
QUOTE(Clipsetuner @ Oct 7, 2005 - 11:15 PM)
[right][snapback]342375[/snapback][/right]
1) You need to charge the capasitor first, by buying some cheap thing (I forgot the name) at RadioShack. Without charging, the cap wont be working at its fullest.
2) Use only the same gauge wires through out the system BY THIS I MEAN: if u use 4 guauge from battery to cap, use 4 gauge from cap to ground. IF u use 8 gauge from cap to to (+) amp use the same gauge to run from cap to amp (-). (it will reduce the resistance so that your wires and amp dont heat up as much). When I was doing my system the first time I ran 4 gauge from cap to (+) amp and 8 gauge from cap to (-) amp. And my amp was getting extremely hot. So I changed the (-) to 4 gauge and now its not as hot anymore.
3) Dont spend extra money on a cap with that stupid voltage meter, you dont need that well unless you are enter your car into shows and need some more show off stuff.
If u are a noob (the person who created the thread not the one who I am replying to) to the car audio go to Crutchfield Help page and read about all the system components and the difference between them. Because, by the way you wronte in your thread it feels like you dont even know that .5 farat cap is made for system's with around 500Watt RMS. And 1.5 farat cap is made for systems with 1500Watt RMS. You should know things like that before you buy a cap cuz the higher tha farat the more $$$ you gonna pay, cuz if you are running a 300Watt RMS system you wont need 1.5 farat cap unless you are going to upgrade you system in the future. But there are some pos. about getting more farats then you need (I got 1.5 farat, cuz I got it off of one of my firends for 40$) which is a pretty good deal. And I am running around 500Watts RMS so there is no way I need all 1.5 farat but hey at least my lights dont dim at all and my battery is as healthy as it was when I bought my car.
This post has been edited by Niskyspy: Oct 8, 2005 - 10:05 AM
<<AKA THA RUSSIAN>>
post Oct 10, 2005 - 5:07 PM
snadman
From Minnesota, USA
Not to mention your alternator. BUT, what niskyspy said is completely correct. Charge the cap, use same gauge both ways etc etc. Only thing is it's spelled Farad not Farat lol
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Oct 11, 2005 - 9:01 AM
Niskyspy
Joined Jan 21, '05
From NY
QUOTE(snadman @ Oct 10, 2005 - 5:07 PM)
[right][snapback]343106[/snapback][/right]
Hey I am from Russia, well I live in NY but this is my forth year of learning english and I got better English SAT score than 40% of American's and I didnt learn english before I came here.
This post has been edited by Niskyspy: Oct 11, 2005 - 9:02 AM
<<AKA THA RUSSIAN>>
post Oct 11, 2005 - 9:14 AM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
QUOTE(Niskyspy @ Oct 11, 2005 - 10:01 AM)
[right][snapback]343311[/snapback][/right]
funny thing is, I believe him. I would say about 80% of Americans do not speak proper english. Hell, I dont :-p
To live, is to suffer
Lo-Fi Version Time is now: November 29th, 2024 - 5:29 AM
