> Struts seem to be loose or something....., struts not locked is this normal??
post Oct 10, 2005 - 10:06 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Ok, I noticed today that my struts tend to move left and right when you rotate them by hand when there not connected with the 2 big bolts that hold them to the rotor/thingy ma jig. Is this normal for the celicas??? I thought that the struts were supposed to be locked in place and not moving at all? I'm guessing that when I turn the steering wheel the same thing happens too!
post Oct 10, 2005 - 10:37 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
There is a certain amount of movement that the struts can make... they turn when you turn, they can flex with compression, etc... so no... they aren't stationary... ;]
post Oct 11, 2005 - 12:33 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The steering knuckle, and the tie rods and controls arms attached to it, are what guide the struts and keep them in line with your car. That's why those bolts are so big...
post Oct 11, 2005 - 1:38 PM
st202gt
Joined Jan 17, '03
From Fresno, CA
one of mine are like that. I am recommend changing one of the blow struct mount.
check maybe you strut mount are going out. also check the your tire, if it chamber in or out. If so, you must replace them.
post Oct 11, 2005 - 4:34 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
My wheels suck, I can feel every pebble, crack, bump, insect I run over on the road. Do you guys have this problem with Low-profle tires?
post Oct 11, 2005 - 6:06 PM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
QUOTE(soulshadow @ Oct 11, 2005 - 4:34 PM)
[right][snapback]343445[/snapback][/right]
DUDE YES!!!!!!!
I have the worst of all things....low pros, body kit, lowered car......man it was ok when i just got the tires and rims, but when i dropped it......its a real pain to drive off the freeway. frown.gif
Lo-Fi Version Time is now: November 25th, 2024 - 6:43 AM
