air bag light??, it went on what could it be? |
Oct 11, 2005 - 7:19 PM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
Ok so my airbag light is on and i dont know why. It wasnt on when i got to work and then 4 hours later i started my car and bam it was on.
any ideas as to why? |
Oct 12, 2005 - 4:19 AM |
? lol
Oct 12, 2005 - 5:01 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Run the codes
-------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 12, 2005 - 10:48 PM |
QUOTE(Dr_Tweak @ Oct 12, 2005 - 6:01 AM) Run the codes [right][snapback]343690[/snapback][/right] this is how. Turn ignition to ACC or "on" and wait 20 seconds. Use a jumper wire in the diagnostics box in the bay and connect Tc and E1. Then count the blinks. 2 per second = normal the codes will be 2 digits. The light will blink x amount of times (first digit) and then pause and then blink another x amount for the second digit. example code 53 - blink blink blink blink blink pause blink blink blink then repeat\ the SRS codes are as follows 11 12 13 14 15 24 31 53 54 if you want the code descriptions and troubleshooting, let me know. -------------------- |
Oct 12, 2005 - 11:42 PM |
mind posting them up?
Oct 12, 2005 - 11:54 PM |
sure, I just did a scan of the page. There is more detailed info on each code, once you know what code you have let me know and I will scan and post all about it
look out, big pic good luck -------------------- |
Nov 4, 2005 - 12:35 PM |
QUOTE(Batman722 @ Oct 13, 2005 - 3:48 AM) QUOTE(Dr_Tweak @ Oct 12, 2005 - 6:01 AM) Run the codes [right][snapback]343690[/snapback][/right] this is how. Turn ignition to ACC or "on" and wait 20 seconds. Use a jumper wire in the diagnostics box in the bay and connect Tc and E1. Then count the blinks. 2 per second = normal the codes will be 2 digits. The light will blink x amount of times (first digit) and then pause and then blink another x amount for the second digit. example code 53 - blink blink blink blink blink pause blink blink blink then repeat\ the SRS codes are as follows 11 12 13 14 15 24 31 53 54 if you want the code descriptions and troubleshooting, let me know. [right][snapback]344030[/snapback][/right] there is not Tc plug. did u mean something else? |
Nov 4, 2005 - 12:58 PM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
what if i just wanted the light off? my airbags busted in the accident in 2000 and its annoying. how do you get if off?
Nov 4, 2005 - 1:37 PM |
QUOTE(easternpiro1 @ Nov 4, 2005 - 1:58 PM) what if i just wanted the light off? my airbags busted in the accident in 2000 and its annoying. how do you get if off? [right][snapback]353041[/snapback][/right] pull the bulb -------------------- |
Nov 4, 2005 - 5:17 PM |
QUOTE there is not Tc plug. did u mean something else? there is a TC pin, not plug. it IS there, in the diagnostics box. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Nov 4, 2005 - 6:29 PM |
Enthusiast Joined Jul 7, '04 From Maryland Currently Offline Reputation: 0 (0%) |
that happen to me about 2 months ago, I had to get a new air bag ecu
Lo-Fi Version | Time is now: December 3rd, 2024 - 11:18 AM |
