> Feeler FS: 20V 4A-GE Conversion Stuff, Harness, AFM, ECU, Ignitor, etc.
post Oct 12, 2005 - 2:43 AM
I'm preparing to run a Megasquirt setup on my car, and I'm wondering if anyone would be interested in a lot of the stuff for a conversion from your 7A-FE to a silvertop 4A-GE.
Stuff I'd have left over for sale would include:
Modified AE101 4A-GE into AT200 chassis harness - This harness would make it so you wouldn't have to do the wiring yourself.
AE101 4A-GE Manual-Tranny ECU - The ECU to run the silvertop 4A-GE.
AE101 4A-GE AFM - The required AFM for the silvertop 4A-GE's stock ECU.
Ignitor - The correct ignitor for the ignition.
MSD Coil - The coil I'm using for my ignition setup. It works perfectly with the rest of the stuff.
With this stuff, you'd only need the 4A-GE engine itself(with manifolds of course.) Then the only work would be swapping it in, getting a bit of custom exhaust work done, and getting the power steering and a/c working if wanted. Everything would plug and play.
So if you would be interested, let me know. This stuff wouldn't be available for a couple months at least, but I'm trying to justify the cost of converting to Megasquirt.
post Oct 12, 2005 - 1:40 PM
Ethnykceli
Joined Jan 14, '05
From Miramar, Florida
i might be interested in all of it
post Oct 12, 2005 - 8:19 PM
celicaST
Joined Jun 23, '05
im interested, im still debating whether to swap or turbo, if i do swap itd be either the 4age or 4agze and itd be nice to not have to do the wiring if i went with ge! only thing is, im wont be able to do either until next summer, but im definitely interested.
post Oct 12, 2005 - 8:40 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Coomer why don't we trade??? I'll get you all the stuff Megasquirt V2.2 extra, 10ft Wiring harness, fuses and holders, EDIS set: trigger disc, coils, spark plugs, EDIS it self, Vr-sensor, 1ft USB-to-SERIAL connector, all softwares and ect.
I got the MS pretty much brand new and tested, but because of fiddling around with the car I didn't have time to install MS. I still have to fix my rear motor mount, and the tranny seal that is now leaking oil. I JUST WANT MY CAR RUNNING WITHOUT DYING!!! frown.gif
post Oct 12, 2005 - 11:21 PM
shazam, I'll throw my hat into the ring. Interested.
post Oct 12, 2005 - 11:24 PM
djspike
Joined Apr 23, '04
From WA
intrested in as well depending on cost
post Oct 13, 2005 - 12:44 AM
FallenHero
Joined Dec 26, '02
From Alabama
Lo-Fi Version Time is now: February 20th, 2025 - 4:30 AM
