FS: 1999 SS3 BEAMS 3SGE engine/trans/WIRING/ECU |
Oct 15, 2005 - 6:47 AM |
Enthusiast Joined Oct 15, '05 From Montreal, Canada Currently Offline Reputation: 0 (0%) |
If anyone is interested, I have another one available, asking 2300$+ shipping since it has a slightly dented manifold:
ECU is included but not pictured email me at craynauld@videotron.ca if you are interested it has unknown mileage but its in the 40k miles ballpark, i didn't get the cluster The transmission is lsd but I do not have the axles(I can find the part number though). Comes with uncut harness up to ECU. I will include The 2000 TOYOTA EPC on DVD which included all the beams part numbers so that you can order them at either www.toyotaworld.com (USA) or www.fensport.com (UK). asking 2300$ usd + shipping(shipping is around 300$) I'm from the MR2 board(www.mr2oc.com) IF you want to check my feedback(100+ positive ones) : click here email me at craynauld@videotron.ca for more info Thanks Chris This post has been edited by rascaca: Dec 21, 2006 - 12:34 AM |
Oct 15, 2005 - 1:09 PM |
Rascaca is a regular poster on mr2oc.com and his trader rating looks great. This is your chance for N/A power boys!
This post has been edited by jgreening: Oct 15, 2005 - 1:14 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Oct 15, 2005 - 6:26 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
So what car does this come from? The tranny is the stock part for the engine?
-------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 15, 2005 - 6:43 PM |
comes from a 6th gen jdm SS3 celica
Oct 15, 2005 - 11:36 PM |
deleted
This post has been edited by rascaca: Dec 21, 2006 - 12:28 AM |
Oct 19, 2005 - 11:28 AM |
wiring pinouts:
This post has been edited by rascaca: Oct 19, 2005 - 11:29 AM |
Oct 19, 2005 - 1:26 PM |
What is needed and not included in the swap(you get whats is pictured):
the beams mass air flow part number is the same as the USDM V6 camry from 1997-2001(1mzfe engine) and can be found at www.car-parts.com for cheap(30$) The intake tubing needs to be found or made from TB to air filter. The right engine mount is only found in 3sge from 96+(3rd gen) and the part number is 12362-74421 (you can order it at the mentionned sites (www links) on first post) (the 2 other mounts missing can be found on the USspec 5sfe GT celica) you will need axles though if you want to use the lsd transmission(you can always use your non lsd one.) part number for the axles inner stub shaft are: 43030-32010 (right) 43040-32010 (left) which are found in the 86-89 gts 5speed celicas I'm not sure if the whole axle fits(don't think so) but I'm pretty sure you can use the 5sfe celica outer joints/shaft with the 86 gts inner shafts/stub. That leaves us with the exhaust that should be donne custom by a muffler shop. I do have the part number but i think it will be ridiculouly expensive to buy it new. |
Oct 19, 2005 - 2:27 PM |
shipping is around 300$ and up to 450$ in california.
The closer to the north east, the cheaper. I'M shipping with UPS freight takes about 3-7 workingdays This post has been edited by rascaca: Dec 21, 2006 - 12:28 AM |
Oct 19, 2005 - 3:17 PM |
Don't forget that it comes with a copy of the Toyota electronic parts catalog which include most/all of the usdm cars up to 2002. most/all of the european car up to 2002, and most/all of the japan car up to 2000 which mean you can search part numbers for alwmost every toyota models and compared them to what we have here...
Chris |
Oct 19, 2005 - 6:13 PM |
Enthusiast Joined Aug 29, '02 From Kelowna, BC Currently Offline Reputation: 0 (0%) |
Also, this is a swap that has been done already. There is BEAMS technical experience on this site now.
-------------------- 1994 GT-S (BEAMS) swap complete |
Oct 19, 2005 - 11:18 PM |
any one interested in ITB's!!!! |
Oct 21, 2005 - 11:43 PM |
just for people wondering, there is nothing wrong with the engine/trans, I'm working at a local japanese importer(part time) and thought you would be interested, i almost considere dit for my Mr2 but changed my mind...still available
Oct 31, 2005 - 8:52 PM |
deleted
This post has been edited by rascaca: Dec 21, 2006 - 12:29 AM |
Nov 1, 2005 - 10:41 PM |
I'm accepting payment ''plans'' let me know what you have in mind...
craynauld@sympatico.ca |
Nov 3, 2005 - 10:26 AM |
deleted
Nov 27, 2005 - 9:10 PM |
QUOTE(rascaca @ Nov 7, 2005 - 10:13 PM) [snapback]354458[/snapback] also, this is a 99 engine, not a 90 3sgte. I do not know the mileage because it came without cluster from japan but if some say that a 90 3sgte has 60k miles, this one can easely 20k miles(i don't know but you get the point) Chris If this engine has no cluster, the tach will not work. I had to swap out my tach with the BEAMS tach to get it to work. The tach signal is different and will only work with the BEAMS tach. -------------------- 1994 GT-S (BEAMS) swap complete |
Nov 28, 2005 - 12:10 AM |
here is the tach part number: 83881-20520
Nov 28, 2005 - 1:49 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Tach is availible on Ebay, for 299$ right now.
-------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Nov 28, 2005 - 10:01 AM |
Dec 2, 2005 - 11:28 PM |
Enthusiast Joined Oct 30, '03 From TEXAS-1 Currently Offline Reputation: 0 (0%) |
would a 5 speed auto tranny work with this?
Lo-Fi Version | Time is now: November 24th, 2024 - 10:42 AM |
