got the projectors, still a question |
Oct 15, 2005 - 11:56 AM |
Enthusiast Joined Nov 22, '03 From Tracadie-Sheila, NB (Canada) Currently Offline Reputation: 14 (100%) |
ok...so now im about the put my projectors that i just received...the low beams seem to have already the little rubber sealing installed all around but the high dont have them....Am i supposed to use the seals from the stock highs?
also...are those rubber need to be glued to the lense or the bumper will be enough to hold it in place? TIA This post has been edited by HaRv3sTeR: Oct 15, 2005 - 11:59 AM |
Oct 15, 2005 - 12:32 PM |
Enthusiast Joined Aug 30, '02 From Ohio Currently Offline Reputation: 0 (0%) |
they don't seal to the high beam.
they seal on the bumper itself. i used a lil silicon to keep mine on. -------------------- Jared Harwell
Oct 15, 2005 - 1:27 PM |
QUOTE(HaRv3sTeR @ Oct 15, 2005 - 11:56 AM) Am i supposed to use the seals from the stock highs? [Do] those rubber [seals] need to be glued to the lense or the bumper will be enough to hold it in place? TIA [right][snapback]344893[/snapback][/right] Yes. Not necessarily, but its a good idea. I would "spot" glue them with good silicone so that they can be removed if necessary. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Lo-Fi Version | Time is now: November 25th, 2024 - 4:22 AM |
