> The big 5sfte post changes, Post em
post Oct 15, 2005 - 5:10 PM
shid
Joined Jan 8, '04
From LA
Pressure just posted the Turbo FAQ links, which made me realized I hadn't completed the big 5sfte post, and there's still some stuff in there that needs to be corrected, added etc.
Knowledgable minds, post that stuff here and I'll edit it in so the post can be semi complete.
post Oct 16, 2005 - 9:36 AM
just a few off the top of my head.
BIGGER INJECTORS
the 315cc supra injectors are just TOO SMALL.
-3an oil feed line w/restrictor.
at LEAST stock sized return (-10an, -12an prefered) and keep the line as straight and kink free as possible
e-manage or simalar over the SAFCII & BTM combo, MUCH better control.
and IMO the biggest thing,
PROPER TUNING!!!!!!
post Oct 17, 2005 - 9:40 PM
urbandork
Joined Jul 16, '04
From Los Angeles
wide band o2 sensor and gauge is always helpful.
post Oct 21, 2005 - 4:04 PM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
presure2 I tryed 7mg(t)e supra injectors they did not pulg up....
the good thing I had some JDM 4age injectors they pulged up fine.... i will take pics...soon..
post Oct 22, 2005 - 5:09 AM
QUOTE(Punch @ Oct 21, 2005 - 5:04 PM)
[right][snapback]347480[/snapback][/right]
supra turbo injectors WILL NOT WORK.
thats a known thing.
the 315s from the NA supra is what we used to use.
post Oct 22, 2005 - 10:26 AM
shin
Joined Aug 21, '04
From New York City
Punch. you're suppose to use the 7MGE injectors not the 7MG(T)E injectors.. but anywho... how big is the 4AGE injectors? for the 5sfte you'll need at least 440cc.
~*MuH NeW RiDe*~
post Oct 23, 2005 - 12:26 AM
Punch
Joined Jan 29, '04
I got the 7mge they did not fit... 7mge & 7mgte pulge are the same...
post Oct 23, 2005 - 5:01 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
my 7mge's fit just fine when I test fitted em and they didn't leak or anything, are you sure you got the right kind? they should look like this
last I knew you could use these for a 5sfte project. I have seen pressure2 post that bigger is better but I am assuming that is due to his HP goals, correct me if that is wrong.. really dont wanna shell out more $ for injectors if I dont have to.
post Oct 23, 2005 - 6:03 AM
Punch
Joined Jan 29, '04
QUOTE(NEVERSTOP @ Oct 23, 2005 - 10:01 AM)
[right][snapback]347983[/snapback][/right]
yes those are the ones the 7mgte injectors are the same pluges...
they did not fit I must have a diffrent model but the 4age injectors are the same size as the 7mge if I go bigger I will get 4agze injectors, or turnup the fuel from the FPR....
post Oct 23, 2005 - 2:54 PM
epinasty
Joined Oct 7, '05
From Kansas
Pressure2 got 200WHP with those injectors right?
Would you say that's the most you can get without going to
the 440cc ones? What if you added a fuel pressure regulator?
This post has been edited by epinasty: Oct 23, 2005 - 2:55 PM
post Oct 24, 2005 - 6:57 AM
NOOOOO
i DID NOT GET 200WHP with those 315s!!!!!!!!!!!!!!!!!!!!!!!!
it was on 460cc injectors.
the 315s are ONLY GOOD for 192whp WIDE OPEN
post Oct 24, 2005 - 12:17 PM
please stop using those damn 315cc green tops! they are just too damn small. just look at mannys dynos to see how lean your car is with those things.
This post has been edited by lagos: Oct 24, 2005 - 12:18 PM
post Oct 27, 2005 - 11:40 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
Well that suites me just fine HP wise, not lookin to break 6gc hp records with mine smile.gif . Has anyone had any problems with these injectors running too lean though?
post Oct 28, 2005 - 6:59 AM
neverstop, id REALLY look @ bigger injectors, even @ low boost, you'll be on the lean side with the 315s, just search around for itchyb dyno charts for an example.
i know i was VERY lean even @ 8-9psi.
post Oct 28, 2005 - 7:33 AM
macavely
Joined Nov 4, '02
this should be this frist thing in really really big red letters.... Do your homework.. read what a turbo is what makes it work .. what an engine needs to make it work right ... what keep it running smooth...
post Oct 28, 2005 - 10:05 AM
neverstop and everyone else,
this pic will give you an idea of JUST how lean it is with the 315cc injectors.
post Oct 28, 2005 - 10:45 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
Can I ask what PSI you where running for those dynos??
I am looking to run 5-7psi max and would like to get away with just using the supra fuel pump, vortec fmu and the injectors I already have. im NOT looking for high hp outta my 5sfte... honestly dont really give a crap about how fast this car is, im really building the thing cuz im bored and have the parts to, and would like to build the cleanest/professonal/effecient 5sfte setup to date. im more concerned about keeping it running and not blowing my internals into future paperweights (blown pistons are great for that wink.gif ). However I do respect your opinion on this pressure cuz you have done the testing/research, so if you think I will need em with my goals then I will get em smile.gif
Thanks
post Oct 29, 2005 - 5:59 AM
never, if your using a '26, you wont be able to run 5 lbs, minimum will be 7.
that run you see there was @ 8 creeping to 9 or so in the upper rpms.
post Oct 29, 2005 - 9:13 AM
ummmx2
Joined Nov 6, '04
if your looking to keep your 5sfe running, then i would DEFINITELY get those injectors. the rx7's arent that expensive in the first place so y not just get them.
post Oct 30, 2005 - 1:33 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
Okay I will get the bigger injectors.. it just kinda frustrating cuz this will be the 3rd set now of injectors I have got for this project.. and I just recently had the 315cc ones cleaned, gonna hang onto em though for now who knows might end up using them if I feel that im running too rich once everything is installed.. sounds like im not gonna be but with my luck I would get rid of em then need em wink.gif
so exactly which injectors do I need then for the 5sfte 440cc or 460cc?? and which gen rx7? and turbo or non? part number would be great also. Are they a direct plug and play or is mods required?
Im sure there was a post all about this and the info is all there but I missed it and I have no luck with the search function on this site
Thanks
NEVER-
Lo-Fi Version Time is now: January 12th, 2025 - 6:04 AM
