valve question |
valve question |
Oct 16, 2005 - 7:50 PM |
hey can i adjust my valves?...i know honda can...i just want to know before i do anything...there's an annoying clicking sound...LMK guys...
Oct 16, 2005 - 8:28 PM |
i think the 5sfe has hydrolic lifters. You can't adjust the valve clearance like honda's.
Oct 16, 2005 - 8:49 PM |
nope your vavles stay there......the clicking, i'd suggest a full tune up, check your timing belt and timing.....and um go to a mechanic
Oct 17, 2005 - 12:08 AM |
get your shim clearences checked...
-------------------- "It's ok to be naked girl... I'm an artist!"
Oct 17, 2005 - 3:05 PM |
your motor isn't bad you just need some vavle train work done or it can go bad......
150 is not bad for vavle train work |
Oct 17, 2005 - 3:55 PM |
like kwanza said, shim clearance.
unlike a small block chevy, you cant just adjust "valve lash" on the celica. it has a shim over bucket design, and valve clearance is adjusted with the shims. basicly you measure the clearance between the shim and camshaft, compare that mesurement to the guide in the BGB and swap out shims accordingly. not quite as easy as it sounds without a good working knowalge of it, and the right tools. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 17, 2005 - 5:38 PM |
Enthusiast Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
yep its its abit difficult take it to a daeler or someone that knows how to do it
Lo-Fi Version | Time is now: December 12th, 2024 - 10:54 AM |
