2 Pages V  < 1 2
> ABS removal, anyone done it??
post Oct 26, 2005 - 1:46 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(mark_426 @ Oct 25, 2005 - 7:20 PM)
Personally,  I think ABS is unsafe. I know two people who have wrecked celi's due to ABS locking up - holly and ashley (in that f'd alltrac)
[right][snapback]348972[/snapback][/right]
ABS "locking up"?
Explain?
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Oct 29, 2005 - 12:24 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
ABS "locking up"?
Explain?
I had this happen to me also one time in my 94 gt, but has never happened with my 99 gt. and I am using the term locking up as in the wheels locked and I skidded. it was in dry driving conditions during summer. I never found anything wrong with the ABS nor did I get any CEL's from it.
post Oct 31, 2005 - 11:28 AM
Mr_E
Joined Nov 16, '04
From UK
I've never, ever had ABS do that. Sounds like it's faulty, but as you say, there should be a code.....
ABS usually fails off. That is, if it detects a fault it disables itself and gives you normal brakes....
JDM ST205
post Oct 31, 2005 - 10:59 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
i think NEVERSTOP clearly stated what this thread SHOULD be about. come on pll if you want to discuss the use of ABS, start ur own thread.
word. i had abs off for a while on my car but then i put it back on b/c i was thinking about selling it. never had any problems when it was off. definitely a lot more fun in the snow.
post Nov 1, 2005 - 12:38 AM
QUOTE(Mr_E @ Oct 31, 2005 - 12:28 PM)
[right][snapback]350973[/snapback][/right]
correct. the ABS is not part of your ECU CELs. The ABS has it's own ABS ECU and if there is a prob with the system (sensor or whatever) it shuts the system down and you have normal braking ability and the ABS light will remain illuminated. You can then read the ABS codes
for reference...(from Manny)
94-95
ignition in the ON position,
bridge E1 & TC in the diagnostics box, just like checking codes, read the code from the ABS light
codes 31-34 are the sensors @ each wheel.
31 Malfunction of right front wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness and connector
32 Malfunction of left front wheel speed sensor signal. Check
33 Malfunction of right rear wheel speed sensor signal. Check
34 Malfunction of left rear wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness, and connector
if you do not have a 94-95 you can go to Autozone or Pep Boys and they can check the code for free I believe.
2 Pages V  < 1 2
Lo-Fi Version Time is now: April 22nd, 2025 - 1:24 PM
