![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
ok so i looked at that how to and found that the diagram does not match up with what it says to do with the black wire coming out of the coil. It says it will be connected to the orange wire from the btm but it shows it being connected to the read.
Manny has typed, in a rush as he had to run, that... PRESURE2: the white wire coming from the coil gets cut PRESURE2: the coil side of the wire goes to the orange from the BTM PRESURE2: the harness side goes to black from the tach adapter PRESURE2: the white wire is white with a blue stripe PRESURE2: then the red from both units tap into the black wwith ornage stripe. but what about the white one from the btm and the gray one from the tach adapter? I know manny was in a rush but perhaps later someone can revize the how to or help me out. id hate to hook the rong wire up to the rong place lol. thanks in advance and no stress on time. |
those both arnt used.
then ist seems like the how to needs a revision.
thanks manny i will try to hook it up today after class if its not raining. |
both the how to and manny speak about the ignition coil being on the driver side firewall.
the only thing ignition related on my drivers side fire wall is a box that says Intition Control on it. It does have the white w/blue strip wire and a black w/orange stripe wire. However these pairs of wires are going in and out from more then one area of the unit. I looked in the haynes book for where the ignition coil is. and it places it behind the distrbutor cap. Does someone have a pic of what i should be tapping into. I c the wires but dont know which ones to tap into as there are more then one pair of them. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) ![]() |
The how to did not work for me either. But I'm OBDII so maybe that matters? The wire colors where the same though. Isn't the white/blue the negative and not the positive? I thought the two color wires where always the negatives?
I have the Tach Adapter and through trial and error and a few popped fuses I figured it out. Then the MSD 6BTM blew my stock coil all to heck. So I go and by the MSD blaster 2 coil (Rocks all by itself - bye bye idle fluxuation - $40 well spent) but now I must have mislabeled the wires and I can't get it to work again. Sux!!!!!!!!! Please help us. Do you think I fried my MSD? It's still under warranty but it takes like a month to get it back. HEEELLLLLPPPPP! BTW - the white wire from the BTM was used on my setup the black went to ground with the other at the Battery (or wherever). This post has been edited by Negative: Nov 4, 2005 - 4:33 PM -------------------- ![]() |
follow the way manny has it hooked up. ill c if i can take pics
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) ![]() |
I'm gonna go witha after market coil also to avoid any problem...
![]() ![]() I got this from MSD mabe it will help... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
ummm. wat is BTM?? Im so confused reading your text. Somebody clearfy this please!
QUOTE(soulshadow @ Nov 8, 2005 - 10:09 PM) ummm. wat is BTM?? Im so confused reading your text. Somebody clearfy this please! [right][snapback]354716[/snapback][/right] Boost Timing Retarder part of the MSD - retards timing based on boost for N/A to Turbo applications. I still need a working diagram for an OBDII GT. The above doesn't work. Please help - I miss the extra response. Pictures from another persons setup or a handmade wiring diagram would be awesome. Thanks in advance. -------------------- ![]() |
Noone has one on a OBDII GT?
still need help - can someone answer the OBDII GT question?
QUOTE(Negative @ Nov 17, 2005 - 11:40 AM) [snapback]356595[/snapback] still need help - can someone answer the OBDII GT question? from your coil there is a plug on it you take the white wire with blue stripe. cut it the coil side of the wire connects to orange from the BTM the harness side goes to black from the tach adapter then you take the black wire with orange stripe from the coil and the red wires from both the BTM and tach adapter tap into that. thats it. ![]() -------------------- Former Team 5SFTE pro member ;)
pics would help a little bit better
QUOTE(presure2 @ Nov 17, 2005 - 7:19 PM) [snapback]356678[/snapback] QUOTE(Negative @ Nov 17, 2005 - 11:40 AM) [snapback]356595[/snapback] still need help - can someone answer the OBDII GT question? from your coil there is a plug on it you take the white wire with blue stripe. cut it the coil side of the wire connects to orange from the BTM the harness side goes to black from the tach adapter then you take the black wire with orange stripe from the coil and the red wires from both the BTM and tach adapter tap into that. thats it. ![]() Many many thanks. My black wire does not have a orange stripe though - does that matter? Remember I'm OBDII - Are you? I had it working before for 6 months untill the stock coil blew. No I have the master blaster coil - much better. I'm thinking I may have fried the MSD. It's still under warranty though. Pics would help but don't put yourself out or anything. -------------------- ![]() |
make sure your coming from the COIL, not the ignitor.
QUOTE(presure2 @ Nov 18, 2005 - 5:29 PM) [snapback]357019[/snapback] make sure your coming from the COIL, not the ignitor. LOL - yeah the first time I did I cut all the coil wires too. Then had to go back and reconnect them and insulate etc. Do you have a digital camera? This post has been edited by Negative: Nov 18, 2005 - 4:11 PM -------------------- ![]() |
ill get some pics this weekend, im going up to install vins setup.
shin good luck drive safe, check your oil all time!!!
QUOTE(presure2 @ Nov 18, 2005 - 9:44 PM) [snapback]357108[/snapback] ill get some pics this weekend, im going up to install vins setup. ![]() Thanks - can you PM me when you get them? I don't often check in here. Thanks in advance. -------------------- ![]() |
Any news yet?
Lo-Fi Version | Time is now: February 22nd, 2025 - 7:09 PM |
