> Oooooohms
post Oct 22, 2005 - 8:58 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Does anyone know what the resistance ratings of the spark plug wires should be on a 94 st? I got
cyl1: 6.53kohm
cyl2: 7.60kohm
cyl3: 8.94kohm
cyl4: 9.65kohm
I may have it backasswards but does that sound right to anyone?
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
post Oct 24, 2005 - 8:34 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
As far as rating goes. It really depends on the length of the wires. tongue.gif
As long as your even getting a rating, you should be fine. Mine has like 0 resistance and 0 conductivity but it still works and will give off a nasty shock if your touching the top of the wires where it plugs into the dizzzy.
post Oct 24, 2005 - 4:12 PM
celicaST
Joined Jun 23, '05
chiltons's says replace any wire that has a resistance of over 25kohms, so your well under that.
Lo-Fi Version Time is now: November 25th, 2024 - 1:19 AM
